car wont stay running unless key is held in certain spot
Old Apr 27, 2005 | 02:58 PM
PGT Driver's Avatar
Default car wont stay running unless key is held in certain spot
okay i have an 85 crx and the car wont run unless i hold the car just before the point where it activates the starter. So i was wondering what the problem could be, if anyone has any ideas let me know.
Old Apr 27, 2005 | 03:13 PM
b17hybrid's Avatar
Default Re: car wont stay running unless key is held in certain spot (PGT Driver)
You need to replace your ignition wiring. That happened to me once and I replaced the ignition wiring and it stopped. Just a suggestion. Go to the junk yard, and it will probably cost you 10-15 bucks.
Old Apr 27, 2005 | 03:41 PM
doublethink's Avatar
the key cylinder itself is faulty. the piece your key goes into is actually a switch that powers ignition accesseory and powers the starter on a full turn.
in order to keep that same key you have now go to the dealership with the vin and get a new one. going to the junkyard will result in you having more then one key to open the car and start it.
Old Apr 27, 2005 | 04:07 PM
MrPotatoeHead's Avatar
Default Re: car wont stay running unless key is held in certain spot (doublethink)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">the key cylinder itself is faulty. the piece your key goes into is actually a switch that powers ignition accesseory and powers the starter on a full turn.
in order to keep that same key you have now go to the dealership with the vin and get a new one. going to the junkyard will result in you having more then one key to open the car and start it.</TD></TR></TABLE>
WRONG......Its the ignition switch.......
Old Apr 27, 2005 | 04:29 PM
crxtreme89h's Avatar
Default Re: car wont stay running unless key is held in certain spot (OnE sToCk CrX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OnE sToCk CrX &raquo;</TD></TR><TR><TD CLASS="quote">
WRONG......Its the ignition switch....... </TD></TR></TABLE>
AKA Ignition starter switch.
Looky here:
http://www.carpartsteam.com/HO....html
Old Apr 27, 2005 | 05:43 PM
deserthonda's Avatar
Default Re: car wont stay running unless key is held in certain spot (crxtreme89h)
get only the electrical portion of the ignition switch get it at the dealer it only cost around $ 40-50 dont waste ur time with junk yard,,,you don't have to remove the whole igniton switch to replace electrical part once you take steering covers off if you look at the back side of ign switch there are 2 little screws remove those, disconnect the plug and it comes right off ,,,,,install in reverse order
Old Apr 29, 2005 | 11:24 AM
PGT Driver's Avatar
thanks guys i will give all this a try and see what i come up with
Tank_EM2
Honda Civic (2001 - 2005)
Aug 22, 2014 08:31 AM
Moog_enep3
Nov 6, 2013 11:03 AM
TypeRod
Mar 11, 2010 01:24 PM
88 EF Hatch
Jun 27, 2009 06:52 PM
wizzards581
12
Dec 11, 2003 06:25 PM
