Help on Conversion PLEASE
Old Apr 27, 2005 | 02:07 PM
ososlow24's Avatar
From: Over Ten Thousand HONDA CIVIC Lakes, MINNESOTA
Default Help on Conversion PLEASE
Does anyone know if the 99-00 civic front end, fit perfectly on a Del Sol conversion???... If not then what cutting and what do I have to do to make it fit For a friend...
Old Apr 27, 2005 | 02:09 PM
menkio's Avatar
Default Re: Help on Conversion PLEASE (ososlow24)
SEARCH
this ******* topic had been covered so many times... LOOK
Old Apr 27, 2005 | 02:56 PM
saxqtzk's Avatar
Default Re: Help on Conversion PLEASE (menkio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menkio &raquo;</TD></TR><TR><TD CLASS="quote"> SEARCH
this ******* topic had been covered so many times... LOOK </TD></TR></TABLE>
you need to cut your existing rad support and weld in the 99-00 one on. Then you need a set of 99-00 civic fenders so you can cut the portion closest to the headlights and weld it onto your sol fenders.
Once you're done with that, everything will bolt on.
Old Apr 29, 2005 | 02:05 PM
ososlow24's Avatar
Default Re: Help on Conversion PLEASE (saxqtzk)
hey thanks
zerogravitycrx
May 18, 2006 12:23 AM
MN DEL SLOW
Nov 29, 2005 02:43 PM
DxBurnoutKing
Welding / Fabrication
Nov 3, 2004 12:40 PM
quanek4
Nov 2, 2003 01:28 PM
midorigreen.
Jul 31, 2002 09:33 AM
