need some info!!!!
i have a 94 civic hatch, b18b swap with a 99 jdm b16 tranny i plan on cracking it open because it is starting to grind third i want to know what are the best gears to put in i know i am going to put in a ls fifth gear but which others should i use!?
.do you plan on staying NA?turbo?i'd stick with the stock gearing if you're staying NA.this would definitely be a good time to install an LSD too.
read the rules:
2.A. Please do not post misleading or unspecific thread titles. Please don’t post “Help Needed” or “Look at this problem.” Make your thread titles specific to the question you are asking
Chris
read the rules:
Chris
fitbmx86
Feb 17, 2008 09:35 PM
