got my new brake system
It is long time ago since I bought some upgrade parts for my turbo teg...well, here is my new AP 4 piston caliper brake kit setup. In Brno (CZ republik) the Stradale F360 Modenas and the GT3 cup Porsches was about 2-6 seconds quicker per lap than me, they beat me in braking distance.......this should be over now. HarrrHarrrHarrr!!!
The calipers weights 4.4 lbs, diameter is 295mm and 28mm thick. The season can start now
EDIT
I tried the Volk te37 7x15 offset 43mm and I need an 5mm spacer to clear the calipers. 5mm is fine w/o changing to longer studs. The SSR type-C 7.5x15 offset 45mm clear the calipers. I also had no probs with Volk te37 7.5x16 offset 42mm
Modified by austrian type-R at 7:39 PM 4/28/2005
EDIT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW »</TD></TR><TR><TD CLASS="quote">nice...go rape some ferraris and porsches!
yeah. that's a sick system.. all you needed is good brake.. now u got it .. go rape those cars.. lets see some vids later
</TD></TR></TABLE>yeah. that's a sick system.. all you needed is good brake.. now u got it .. go rape those cars.. lets see some vids later
those are Hot!
what pads are you able to run with them?
Next track day I expect to see you passing the Porsches in turns
So post up vids when you can!!!
A friend of mine clear the brake system with his oem Enkai ITR 15x6inch offset 50mm rims
.......AP says it requires at least 15x7inch...but it depends on the spoke design and offset as well.
It was importpant for me to have a strong brake system which clears 15inch rims, since all of my race rims are 15inchers and I like to have as less as possible unsprung weight
.......AP says it requires at least 15x7inch...but it depends on the spoke design and offset as well.It was importpant for me to have a strong brake system which clears 15inch rims, since all of my race rims are 15inchers and I like to have as less as possible unsprung weight
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">those are Hot!
Ferrodo DS3000 pads. ....better I buy 2 spare discs, cause this pads are shaping of the material of the discs verys quick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by austrian type-R »</TD></TR><TR><TD CLASS="quote">It was importpant for me to have a strong brake system which clears 15inch rims, since all of my race rims are 15inchers and I like to have as less as possible unsprung weight
Man, if those clear 15" wheels than I am interested big time. I also use only 15" wheels and have always thought the caliper choices were a bit scarce. Where can I get more info? Do you have part numbers or anything?
Please post new vids ASAP...
</TD></TR></TABLE>Man, if those clear 15" wheels than I am interested big time. I also use only 15" wheels and have always thought the caliper choices were a bit scarce. Where can I get more info? Do you have part numbers or anything?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by austrian type-R »</TD></TR><TR><TD CLASS="quote">A friend of mine clear the brake system with his oem Enkai ITR 15x6inch offset 50mm rims
.......AP says it requires at least 15x7inch...but it depends on the spoke design and offset as well.</TD></TR></TABLE>
Hell yeah
.......AP says it requires at least 15x7inch...but it depends on the spoke design and offset as well.</TD></TR></TABLE>Hell yeah
check the AP homepage out. There are actualy 2 brake kits for 15inch rims.
One with fixed rotors and one with "simming" rotors....but the AP tech told me the swimming rotors realy benefits of they have larger diamter like 330mm up to compensate disc warp. You want the Integra type-r DTC kit, it is part number:
CP3307-1051
Competition Brake Kit for Honda INTEGRA
Technical Information: Caliper CP3307 4 POT Disc CP3580-102/3G8M,
Ø295 x 28mm, 8 groove, 48 Vane, (bolted disc).
Pad CP3215D50 Wheel Honda 7J X 15 5 SPOKE
I payed 2500 euro for the system which is of 2 discs, 2 calipers, mounting parts and a set of Ferodo DS3000 pads. I think I got what I payed for
CP3307-1051
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sim shadeee »</TD></TR><TR><TD CLASS="quote">whoa 3200$ for brakes. I never heard of the company but those brakes look beefy</TD></TR></TABLE>
I know the WRC Mistubishi Evos have used them for a number of years (up until the Evo 6 TM I believe) with which Tommi Makenin won 4 consecutive WRC titles.
Ferodo DS3000 pads
please note: the brake dust from these pads are corrosive, make sure you wash your wheels and car OFTEN
That's about what a Brembo big brake kit goes for, however it doesn't fit under 15" wheels like the AP system.
Modified by zygspeed at 6:16 PM 4/27/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Factor »</TD></TR><TR><TD CLASS="quote">pretty overkill for an ITR but one sick caliper and set of rotors to say the least!</TD></TR></TABLE>
Uh....i really dont think this is THAT much overkill on a car like his.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N »</TD></TR><TR><TD CLASS="quote">
Uh....i really dont think this is THAT much overkill on a car like his.</TD></TR></TABLE>
Just what I was about to say... when you rolling past ferraris and cup porsches on the straight aways... I think he deserves better brakes
+1 for new exotic killa videos
Drinker
