Suspension & Brakes Theory, alignment, spring rates....
1993 acura integra front suspension question
Old Apr 27, 2005 | 10:27 AM
vtec-adykt's Avatar
Default 1993 acura integra front suspension question
i've got a slight problem with a 93 2dr. integra that i just purchased. the sound is coming from the front driver's side. It's a small "pop" sound that occurs only when i take off from a stop, and as soon as i come to a complete stop. It's not a continuous clicking sound like you would hear from a bad axle, it's just one small "pop". And it does it while keeping my wheels straight forward, so i know its not a bad axle. Anyone ever had this problem? If so, what have you done to fix it? thanks.
Old Apr 27, 2005 | 10:49 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: 1993 acura integra front suspension question (lazyeyez)
My CRX had a similar problem (same suspension type as yours). It would pop under med-heavy braking. Sometimes I could hear it pop back when I would start moving again. Here is what I did & it went away. I know it's a lot of things, but you at least know what to get in there & check out...
Rebuild front crossmember/radius rods including lightly sanding chassis mating surfaces & replacing washers & bushings.
Replace front transmission mount on crossmember.
Replace all LCA bushings.
Replace all swaybar & endlink bushings.
When my 92 civic was poping during Accel/Decel, it turned out to be damaged lowerballjoints. I knew that was the problem though since I had messed up the balljoint studs. The castle nuts wouldn't bottom out all the way on the LCA because the threads were messed up. I had them replaced & that solved that one...
Old Apr 27, 2005 | 10:53 AM
vtec-adykt's Avatar
Default Re: 1993 acura integra front suspension question (94eg!)
so i guess it isnt just a common problem in DA integras. I was hoping someone had experienced this problem in the same style car as i have, But i guess their all about the same.
Old Apr 27, 2005 | 11:15 AM
94eg!'s Avatar
#1 Super Guy
Loved
The 88-91 CRX/Civic is the same exact setup as the DA.
Old Apr 27, 2005 | 12:28 PM
Dave421's Avatar
My experience usually shows this to be the balljoint.
Old Apr 27, 2005 | 01:06 PM
vtec-adykt's Avatar
Default Re: (Dave421)
i'll check both the upper and lower ball joints this evening. How will i know if one of them needs to be replaced? Will it be obvious?
Old Apr 27, 2005 | 01:49 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (lazyeyez)
Generally, you just jack the car up & put it on jack stands. Next you grab the front wheel & wiggle it left/right, then up/down. If there are any noises, you will have to have a friend wiggle the wheel while you hunt down the problem.
Also check to make sure that there is no space between the balljoint boot & the LCA or knuckle...
Old Apr 27, 2005 | 01:52 PM
vtec-adykt's Avatar
Default Re: (94eg!)
sounds like a good idea! I'll experiment this evening and post the outcome tommorrow. thanks!
specbb6
Dec 19, 2012 01:01 PM
IP RACING
Jan 10, 2010 09:38 PM
Stricly JDM
Nov 14, 2008 06:32 PM
cho76ers
Jan 3, 2006 08:23 PM
poppycock
May 7, 2004 10:14 PM
