Who makes alum rear LCR's??? CRX
I need to lighten the car alittle was wondering who make's the light weight alum rear control arms? anyone have any problems? any input would be great thanks! Rob
BTW 90 CRX
BTW 90 CRX
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">Function 7</TD></TR></TABLE>
Web addy? and price? thanks Rob
i know u can get the type r control arms from jhp.com,, they usually sell them in the omni coilover kits since omni doesn't make a alum on for 88-91 civic/crx's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReDHaTcHy97 »</TD></TR><TR><TD CLASS="quote">i know u can get the type r control arms from jhp.com,, they usually sell them in the omni coilover kits since omni doesn't make a alum on for 88-91 civic/crx's</TD></TR></TABLE>
Will EK LCR's fit?
and those fuction 7's are sick but way out of my price range! Rob
Will EK LCR's fit?
stock honda...you are only going to save 2lbs rob...not worth the extra 200 bucks...might as well take the 200 bucks, go to the gym and make your wife happier...
j/p
j/p
so, new ones from honda have new bushings as well and are pre-drilled for sway bars...and they are shinney black as well...when i got my new ones i didnt want to put them on cause they were so nice...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">Function7 Engineering</TD></TR></TABLE>
When looking at that website at the ones the have for sale ... Why does only the 88 CRX use a different LCA compared to all the 89+ CRX, Civics?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Imadreamer1226 »</TD></TR><TR><TD CLASS="quote">
When looking at that website at the ones the have for sale ... Why does only the 88 CRX use a different LCA compared to all the 89+ CRX, Civics?</TD></TR></TABLE>differnt shock mounting, they use some wierd ball/cup looking thing
I believe it was a cost decision by Honda. They went to the cheaper cast ones on the US and the majority of Euro Civic/CRX/Integra models while the JDM models kept the 88 CRX type of arms all the way through to the EG Civic and DC Integra. The arms re-appeared on the US ITR albeit with stiffer bushings.
A second factor was handling. The lighter stamped arms made the tail end of the cars more responsive, and perhaps Honda was afraid of getting lawsuits because some (less skilled) drivers would lose control.
-A
-A
***** out pics?! Damn, everyone can see my Rear LCA's on my sedan, imagine the shiny metal bling factor at night reflecting from headlights
Either way I am getting a set this summer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Function7 »</TD></TR><TR><TD CLASS="quote">
-A</TD></TR></TABLE>
the rear lower control arms have absolutely no affect on the steering/handling differences between USDM 88 and 89-91 CRX.
youre parroting bad info. please stop.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">
i've always thought this the difference as well. why don't you fill us in?
you have disc or drum brakes?.. if you have drum brakes.. you can use 87 hf rear drums.. thats about 2 pounds less rotating mass than the cast iron drums.. and 10 pounds lighter than disck brakes per wheel...
i dont mean to hijack, but heres your proof.
picture of a 88 CRX
picture of a 89 CRX
you can make out that the 88 has the bottom end of the stamped metal toe piece welded nearly flush with the bottom pan of the chassis. on the 89 however, its obviously raised about an inch higher.
this ALONE is the difference in the toe change found in 88 cars, and not 89-91.
the story goes that honda of america was involved in the late 80's/early 90's ESCORT/FIREHAWK road racing series, which is what world challenge has become now. honda fielded some CRX's in that race. the cars were supposed to run near stock height. the problem was that when the car brakes really hard, the back wheels toed out too much, making it hard to control for the drivers. so they gave honda of japan the feedback and they changed it by the next year. as you can see, the change was very simple but effective.
lets put an END to first of all the myth that 88's had passive rear steering and 89+ didnt. secondly, the stamped box end arms that the 88's had (and shared in design with Type R's) has NOTHING to do with the extra toe curve exhibited by the 88's.
the change is in the chassis.
btw, any difference in the toe curve is all neglible when you lower the car on either model.
picture of a 88 CRX
picture of a 89 CRX
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fortynineR »</TD></TR><TR><TD CLASS="quote">you have disc or drum brakes?.. if you have drum brakes.. you can use 87 hf rear drums.. thats about 2 pounds less rotating mass than the cast iron drums.. and 10 pounds lighter than disck brakes per wheel...</TD></TR></TABLE>
btw, i think the drums are a lot more than 2 lbs lighter. theyre pretty damn light.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">tthe story goes that honda of america was involved in the late 80's/early 90's ESCORT/FIREHAWK road racing series, which is what world challenge has become now. honda fielded some CRX's in that race. the cars were supposed to run near stock height. the problem was that when the car brakes really hard, the back wheels toed out too much, making it hard to control for the drivers. so they gave honda of japan the feedback and they changed it by the next year. as you can see, the change was very simple but effective.
We've been told the same by one of our testers (he ran a CRX for a few years in the world challenge series, and still drives it at track events) about the revision on the rear toe linkage point to address toe-out issues during braking. This was some time ago and your post serves to confirm this.
-A
-A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsca_crx »</TD></TR><TR><TD CLASS="quote">85 -87 hf drums are all the same, right?
not exactly.. hen i was searching for a set... i found some 85-87 hf's that had the cast iron drums.. you can tell the difference because the aluminum drums are finned...
[QUOTE=Tyson]btw, i think the drums are a lot more than 2 lbs lighter. theyre pretty damn light.</TD></TR></TABLE>
ycorrect.. i actually have both drums in front of me and weighed them both on a bathroom scale... and .....
cast iron drums= 7lbs
aluminum drums=3 lbs
