obd2 to obd1= code 21
After swapping out my obd2 ecu to a p28 I'm getting code 21 which is for the VTEC spool solenoid valve. My oil is tipped off so its not the oil pressure causing it. Has any had this type of problem before?
I tried searching but couldn't find a definte answer...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlkSIvic »</TD></TR><TR><TD CLASS="quote">After swapping out my obd2 ecu to a p28 I'm getting code 21 which is for the VTEC spool solenoid valve. My oil is tipped off so its not the oil pressure causing it. Has any had this type of problem before?
I tried searching but couldn't find a definte answer...</TD></TR></TABLE>
That code doesn't have anything to do with oil presure. The ECU isn't sensing the VTEC solenoid. Check to make sure it's good, then check your wiring and connectors.
djSALIX
Jun 28, 2005 09:13 PM
