Vtec Malfunction
Old Sep 28, 2004 | 09:25 PM
97dc2's Avatar
Default Vtec Malfunction
I keep getting a code 22 from my 97 gsr and i fixed everything that people could think of and i still keep getting it. on the obd1 a code 22 is the oil pressure so i changed everything to do with it but i have an obd2. On the obd2 a code 22 is a vtec malfuction but i have no idea what i should do to try to fix it?
How can I fix it?
Also when i redline in 1st gear i hear a spiting sound coming from the engine
Old Sep 28, 2004 | 09:28 PM
ProjectDarkBlack's Avatar
Default Re: Vtec Malfunction (97dc2)
umm nake sure your oil system is set then check the wiring, and the solenoid. thats all i know of
Old Sep 28, 2004 | 10:10 PM
furious94ls's Avatar
Default Re: Vtec Malfunction (ProjectDarkBlack)
Check your oil level.
Old Sep 29, 2004 | 05:34 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97dc2 &raquo;</TD></TR><TR><TD CLASS="quote">... so i changed everything to do with it...</TD></TR></TABLE>What do you mean everything? I guess that would include your oil pickup, oil pump, oil filter, etc...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97dc2 &raquo;</TD></TR><TR><TD CLASS="quote">... On the obd2 a code 22 is a vtec malfuction but i have no idea what i should do to try to fix it?</TD></TR></TABLE>Actually it's the VTEC oil-pressure switch.
Being OBD-2, P1259 is a general VTEC malfunction.
P2646 VTEC Oil Pressure Switch Circuit Low Voltage
P2647 VTEC Oil Pressure Switch Circuit High Voltage
The following 2 codes would have been 21 by the flashing-light method.
P2648 VTEC Solenoid Valve Circuit Low Voltage
P2649 VTEC Solenoid Valve Circuit High Voltage
Old Sep 29, 2004 | 07:41 AM
artifex's Avatar
say it
i threw this code a while back after i changed my clutch (don't know what caused it). i pulled off the vtec solenoid, cleaned it with brake cleaner, and put it back on. problem solved. give it a try, it just might work.
ITR32
May 16, 2007 07:42 AM
shaggy420
Jan 22, 2007 05:09 PM
BlkSIvic
Apr 27, 2005 05:16 AM
Kyles ej1
18
Sep 26, 2004 04:40 PM
selena
11
Jul 25, 2004 05:34 PM
