help b16a hatch help!!!
Old Apr 26, 2005 | 10:06 PM
redED9Si's Avatar
Default help b16a hatch help!!!
alright heres what I got going on..I think it might be the timing i guess...well heres what happens...I start up my car right.. when I start it..it will idle really low like 400-500 rpm.. then will slowly pick up to 1500 or so...then back down to like 1000-750... I start driving it drives fine runs good..then when I stop... sometimes the engine rpm will die sometimes it will bounce up and down between 200 to 1400 rpm... I don't know if it s the alternator belt or the timing someone help me out!! when the car idles you can here the altnernator belt kinda a hair..does really seem bad tho
-Geoff
90 Civic Si (b16a)
Old Apr 26, 2005 | 10:14 PM
hnoppenberger's Avatar
Default Re: help b16a hatch help!!! (redED9Si)
are u getting an engine light? its prolly ur map sensor is toast. its prolly sending out wierd signals, if u know how to test it do it. or get a new one.
Old Apr 26, 2005 | 10:20 PM
redED9Si's Avatar
Default Re: help b16a hatch help!!! (hnoppenberger)
no CEL??
Old Apr 26, 2005 | 11:56 PM
Redline130's Avatar
Check for any vaccum leaks.
Old Apr 27, 2005 | 01:33 AM
nelsmar's Avatar
had a few idle problems cant remember how i fixed them. I do remember when i lowered the idle it fixed my last one.... never thought a high idle could make the idle bounce. move your TPS around see if it fixes it, if its riveted it should be fine and doesn't need to be tampered with
Old Apr 27, 2005 | 01:44 AM
96-EJ6 B18C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redED9Si &raquo;</TD></TR><TR><TD CLASS="quote">alright heres what I got going on..I think it might be the timing i guess...well heres what happens...I start up my car right.. when I start it..it will idle really low like 400-500 rpm.. then will slowly pick up to 1500 or so...then back down to like 1000-750... I start driving it drives fine runs good..then when I stop... sometimes the engine rpm will die sometimes it will bounce up and down between 200 to 1400 rpm... I don't know if it s the alternator belt or the timing someone help me out!! when the car idles you can here the altnernator belt kinda a hair..does really seem bad tho
-Geoff
90 Civic Si (b16a)</TD></TR></TABLE>
Funny, I thought Honda's came stock with an idle surge LOL
Pull the IACV off the back of the intake mani and spray it out with carb cleaner, if that doesn't fix it try playing with the idle screw.
Old Apr 30, 2005 | 08:12 AM
jdmitr's Avatar
Default Re: help b16a hatch help!!! (96-EJ6 B18C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96-EJ6 B18C &raquo;</TD></TR><TR><TD CLASS="quote">Funny, I thought Honda's came stock with an idle surge LOL
Pull the IACV off the back of the intake mani and spray it out with carb cleaner, if that doesn't fix it try playing with the idle screw.</TD></TR></TABLE>
I agree! It most likely is IAC or the small passage way to let air into the IAC on the throttle body is clogged. If it was a vacuum leak it wouldn't go so low, unless your idle adjust screw was all the way closed. Good luck!
Old Apr 30, 2005 | 09:10 AM
D-Rizzle's Avatar
It might be the TPS like that one guy said, my friend has a probe that did the same thing, and we just unplugged his TPS and now it does fine, other than his check engine light being on.
Devon_Arden
Mar 2, 2015 12:19 AM
NA_EF
Apr 12, 2006 09:39 PM
Kooner450r
Dec 27, 2004 09:33 AM
