stupid question, b16a engine into crx.
Old Apr 26, 2005 | 10:00 PM
hnoppenberger's Avatar
Default stupid question, b16a engine into crx.
im new to hondas, but im lookign get ahold of a b16a engine and put it into a 90 or 91 crx si, things i would need are.
-engine
-trans
-ecu
-harness
-3 piece mount kit
-drive shafts
sounds about right?
Old Apr 27, 2005 | 01:09 AM
Redline130's Avatar
Default Re: stupid question, b16a engine into crx. (hnoppenberger)
You will also need a modified shift linkage. You will also need new radiator hoses as well. I would also suggest changing the timing belt, water pump, clutch assembly, thermostat, and any other PITA parts before your drop the B16 into the CRX.
Old Apr 27, 2005 | 11:52 AM
Default Re: stupid question, b16a engine into crx. (Redline130)
does it need different type of hoses? or is it just becuase they SHOULd be changed due to age?
Old Apr 27, 2005 | 12:09 PM
o-man's Avatar
From: living too close to Karl, everythings busted, nc
try this link http://home.wideopenwest.com/~tschmidt/
jdm_dk
Jul 25, 2008 04:19 AM
barry11j
Jul 16, 2004 02:59 PM
chulopilong
Feb 20, 2003 08:04 AM
samagon
Jun 21, 2002 07:08 AM
crxforum
Dec 30, 2001 05:26 AM
