Suspension & Brakes Theory, alignment, spring rates....
ITR SUSP. ON MY EM1?
Old Apr 26, 2005 | 08:36 PM
ricedoutride's Avatar
Default ITR SUSP. ON MY EM1?
i have a 99 civic Si. i'm buying a ITR suspension of a damaged Type R. my current suspension consist of
1.Tein S.S.
2. Cusco strut bars,tie bars, anti roll bar
3.SRR RLCA
4. ingals camber kit front and rear.
will the ITR uspension work with this setup? any modifications i'll have to do? any help would be greatly appreciated
thanks
David
Old Apr 27, 2005 | 10:05 AM
Default Re: ITR SUSP. ON MY EM1? (ricedoutride)
TTT
Old Apr 27, 2005 | 10:52 AM
94eg!'s Avatar
#1 Super Guy
Loved
Everything should work, but your going to need to retain your SSR rear LCAs. ITR ones are not compatable with the EK chassis or shocks. Also, you will need to retain your front LCAs if you already have a front swaybar hooked up...
You will also need a 1" ITR master cylinder for the larger brakes (99 Si Master Cylinder is only 7/8"). I have heard that it is a "bolt on" part for the Si brake booster, but I cannot confirm that personally...
Old Apr 27, 2005 | 03:26 PM
Default Re: ITR SUSP. ON MY EM1? (94eg!)
thanks for the advice, well here gos my setup any problems with it let me now please
1.00 ITR suspension(5lug)
2. Tein s.s.
3. Cusco trut bars, tie bars, rear roll bar
4. ingals camber kit frontand rear
5. SRR rlca
6.Type R master cylinder
well there it is i'm going to be installing the ITR suspension when go one leave from Afganistan in July, i'll be sure to post pics
Old Apr 28, 2005 | 07:33 AM
94eg!'s Avatar
#1 Super Guy
Loved
Good luck
MaaseyRacer
19
Aug 14, 2004 08:33 AM
rubens
Jun 21, 2004 11:50 AM
Transport
10
May 12, 2004 07:04 PM
rbf351
Jun 20, 2002 12:21 PM
WAFFLES
Jan 21, 2002 11:57 AM
