my car runs like crap ..
Old Apr 26, 2005 | 08:18 PM
777sC's Avatar
Default my car runs like crap ..
well here is the problem .. ..
car --- 95 GSR
Temp needle keeps jumping around and the upper rad hose was getting hot and hard while the lower one was cold and hard.... went basically to the H and jumped around back and forth so i turned on the heat and drove home and made sure it didn't overheat
Took the thermostat out so i can see if that is the problem .. well it still jumps up and down but only runs a little bit cooler with no thermostat....
Wondering if its a bad head gasket or it has something to do with anything else it might be
Old Apr 26, 2005 | 08:42 PM
93turbo16's Avatar
Could very well be the headgasket...
Old Apr 26, 2005 | 08:55 PM
notstock93's Avatar
Default Re: (93turbo16)
Yep, could be a HG. Are you smoking? Oil in the coolant, ETC?
Old Apr 26, 2005 | 08:59 PM
777sC's Avatar
Default Re: (notstock93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notstock93 &raquo;</TD></TR><TR><TD CLASS="quote">Yep, could be a HG. Are you smoking? Oil in the coolant, ETC?</TD></TR></TABLE>
no oil in the coolant .. a little smoky when i start the car but after its no smoke ..
car ran fine for like 3 weeks after i put this head on ... (reused head gasket with copper spray) and all of the sudden it started to do this ..
Old Apr 27, 2005 | 08:49 AM
79 civic's Avatar
Default Re: (777sC)
do not re-use head gaskets
Old Apr 27, 2005 | 03:20 PM
sickerhatch's Avatar
Default Re: (79 civic)
reusing a hg is a terrible idea!!!
Old Apr 27, 2005 | 09:25 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 79 civic &raquo;</TD></TR><TR><TD CLASS="quote">do not re-use head gaskets</TD></TR></TABLE>
joel95ex
Mar 24, 2013 06:28 AM
deanandon
Honda Civic (2001 - 2005)
Jan 3, 2013 08:16 PM
nghtshd88
Apr 23, 2011 03:31 PM
Simple SOHC
Jul 1, 2006 11:22 AM
SNsLude
Jul 7, 2005 11:12 AM
