Flywheel Bolt stripped
Old Apr 26, 2005 | 07:47 PM
BbOi0420's Avatar
Default Flywheel Problems HELP PLEASE
So, heres my situation:
I have a b18b i got from HMO a few months back. it appeared to be from an automatic. i was in the proccess of removing the 8 bolts that hold the flex plate, i beleive thats what it is, and now two of the bolts are stripped. i went to sears and got bolt out kit but that just fucked it up even more. they are really shallow bolts so i dont know what to do.
it is the 1 and 3rd bolts from the top that wont come out. Should i just try to drill it out?
HELP PLEASE
Old Apr 26, 2005 | 08:21 PM
BbOi0420's Avatar
Default Re: Flywheel Problems HELP PLEASE (BbOi0420)
anyone else have this problem?
Old Apr 26, 2005 | 08:35 PM
PURPLETERROR aka BIGMATT's Avatar
grind the head of the bolt off, finish removing the flexplate, and use a pair of vicegrips to turn the bolt out
Old Apr 27, 2005 | 12:41 AM
BbOi0420's Avatar
Default Re: Flywheel Problems HELP PLEASE (PURPLETERROR)
youve done this before and it has worked?
Old Apr 27, 2005 | 09:56 AM
PrettyLude's Avatar
that method will work, just make sure you don't grind the head off too far in that the vise grips can't grip it
Old Apr 27, 2005 | 10:00 AM
BbOi0420's Avatar
Default Re: (PrettyLude)
ok ill try that thanks
Old Apr 30, 2005 | 10:25 PM
Garcia-Racing's Avatar
Works fine. I did ther same thing a couple of weeks ago. Note to self. REMOVE WITH BREAKER BAR ,NOT IMPACT.
Old May 1, 2005 | 02:58 AM
GAME OVER 2007's Avatar
Default Re: (Garcia-Racing)
sounds great, hopely ht has help you
Yelowfever
Jul 10, 2007 08:06 PM
93civic2005
20
Jan 11, 2007 02:53 PM
all motor b20b
Feb 19, 2005 12:00 AM
giooooo
Feb 6, 2003 08:25 PM
syndicate43
Nov 25, 2002 05:49 PM
