need some serious help!
Old Apr 26, 2005 | 07:06 PM
lucky_dfr's Avatar
Default need some serious help!
ok, i'm new to honda's in general, i drive a 240 but it's still off the road and i've been witout the honda for a month now. sorry i KNOW i should have searched first, i'm just so frustrated at the moment, i'd really rarther a real person answer me.
what happened. got rearended in my 92 civic, motor popped about 20km later, valve dropped into combustion chamber and blew a hole in piston and wrecked head.
Bought a 90 d15b2 motor swapped everything over to make it work, installed it, turned it over, snaped a rod.
so the motor thats in the car as of now, d15b7 block d15b2 head, and b7 distributer.
here's the problem, it turns over, but won't fire. I've tried every trick i know, the ebst i can do is get it to sputter.
Checked spark, tons
Checked fuel, tons
checked base timing, perfect
checked firing order by p[utting #1 to TDC an pulling dissy cap, perfect
clamped off feed fuel line ( this works on my ca18det when it floods out)
checked for fouled plugs, fine, heated up with propane torch.
no fire, no go. i'm all out of ideas
now here's the thing about the head and dissy, only the top bolt line up, and 1 tab is about 1" off. so really i'm wondering if it could be the distributer
I've got a d16y8 kicking around, if it turns out to be the dissy, i'd trade that for a dissy if need be.
thanks!
Lucky.
Old Apr 26, 2005 | 07:11 PM
SOHC4life 96's Avatar
Default Re: need some serious help! (lucky_dfr)
Kinda easy, but are the plugs gapped correctly?
Old Apr 27, 2005 | 01:50 PM
lucky_dfr's Avatar
Default Re: need some serious help! (SOHC4life 96)
yes plugs are gapped correctly
please i'm desperate. it turns and sorta catches but thats it. no good.
Old Apr 27, 2005 | 02:42 PM
Hatch It's Avatar
I would bet on the dizzy....good luck
Old Apr 27, 2005 | 03:30 PM
lucky_dfr's Avatar
Default Re: need some serious help! (Hatch It)
well here's the new problem, i picked up an EF dissy, problem lies in that, the EF dissy has a 2 pin connector and 5 pin connector...the EG harness has a 2pin and 7 pin connector...uh oh.
anyway to swap the internals from dissy to dissy?
Old Apr 27, 2005 | 03:36 PM
Hatch It's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lucky_dfr &raquo;</TD></TR><TR><TD CLASS="quote">
anyway to swap the internals from dissy to dissy?</TD></TR></TABLE>
yikes, why not just search for the exact dizzy instead of going through all the trouble?
Old Apr 27, 2005 | 05:19 PM
lucky_dfr's Avatar
scre it, i gave up and sent it to a local shop. he's gonna fix it in exchange for my d16y8 with a thrown bearing....i know but i got it for $50 so no loss to me!
smokecdxx
17
Jun 12, 2007 06:09 PM
spooncivic28
May 26, 2006 12:59 AM
spooncivic28
11
Apr 30, 2006 11:52 AM
WhiteTegSE
May 3, 2004 09:20 PM
