suspension woes need help ASAP
Old Apr 26, 2005 | 06:53 PM
gnar kill's Avatar
Default suspension woes need help ASAP
I hit a curb today......bent my rim, popped my tire......pretty much F!@!$ up my whole front right suspension, control arm is bent, radius rod is broke......it is a 91 crx si...I picked up a 90-93 integra suspension today will it work? I got pretty much everything for both sides, control arm, wishbone arm, upper ball joints, brakes, hubs, rotors......is there anything that will not work???? is there anything else I need? thanx
CAsey
Old Apr 26, 2005 | 07:10 PM
gnar kill's Avatar
Default Re: suspension woes need help ASAP (gnar kill)
bump I need help I don't even know if this will work or not can someone please give me some input
Old Apr 26, 2005 | 07:12 PM
HatchBox's Avatar
Skoobie no more...
You can use the knuckle, and brakes.
But in order to keep your geomitry of your alignment corret you need civic upper and lower control arms
Old Apr 26, 2005 | 07:17 PM
gnar kill's Avatar
Default Re: suspension woes need help ASAP (HatchBox)
so the integra ones won't work....even if I get it aligned at a shop
Old Apr 26, 2005 | 07:19 PM
HatchBox's Avatar
Skoobie no more...
im not sure about the lower control arm but i know the upper one needs to be switched.
Old Apr 26, 2005 | 09:40 PM
gnar kill's Avatar
hmm....I think I might be able to reuse my stock one.....maybe .....I have an adjustable camber kit do you think that would help make up for the differenct??
anybody else have any ideas or any thing that would help me out??
Old Apr 26, 2005 | 09:59 PM
gnar kill's Avatar
anyone??
Old Apr 27, 2005 | 06:51 AM
gnar kill's Avatar
ttt
sbuilt2ride
Suspension & Brakes
Oct 16, 2009 08:04 AM
honda-accord
Feb 1, 2006 01:54 PM
iHATEspeedbumps.
Jul 6, 2005 03:41 PM
