MPFI Swap with Z6 Intake Mani and Dizzy??
Old Apr 26, 2005 | 03:57 PM
eumoria's Avatar
Default MPFI Swap with Z6 Intake Mani and Dizzy??
I searched but only found info about non-OBD dizzys on OBD1 heads, not really anything for the other way around.
Is it possible to do a MPFI swap on a D15B1 with a Z6 intake manifold and Dizzy? The plugs are OBD1, so I guess I don't need the resistor box, but the dizzy is also OBD1... is that a problem?
I'm not even sure if the Z6 dizzy even bolts on the same way as the older ones. I want to use a 91 SI ECU so I think it's def not going to work with the OBD1 injectors and Dizzy. I have no clue what works between non-OBD and OBD1 stuff.
Thanks in advance!
Old Apr 27, 2005 | 09:15 AM
eumoria's Avatar
Default Re: MPFI Swap with Z6 Intake Mani and Dizzy?? (eumoria)
Old Apr 27, 2005 | 09:57 AM
Rywire's Avatar
Yes, its very possible, I do that all the time at rywire.com Its not much different going obd1 and mpfi at the same time, just match all the pins, and make sure you do your mpfi correct. If you need help, pm
You need a obd1 ecu as well if you dont allready have that
Modified by droppedcrxsi at 8:18 PM 4/27/2005
eg6civic1538
Feb 28, 2009 01:03 PM
crx-90
May 15, 2008 11:53 PM
downsycrx
Sep 25, 2006 10:52 AM
richboi
11
Apr 17, 2006 04:36 PM
^Sammy]!.
May 9, 2004 04:09 PM
