Camber Kits
Old Apr 26, 2005 | 03:25 PM
LilMrTinnie's Avatar
Default Camber Kits
Anyone know where I can get some instruction on installing these? I've searched and found nothing. Thanks in advance.
I really need it.. I just dropped my ek hatch and the camber is crazy lol.
Old Apr 26, 2005 | 03:27 PM
Luserkid's Avatar
Default Re: Camber Kits (LilMrTinnie)
You remove the upper control arm and put the camber kit one in.
For the back you take off the upper control arm and put washers. Its pretty straight forward.
Old Apr 26, 2005 | 03:29 PM
Default Re: Camber Kits (Luserkid)
washers? Aren't there kits that include rears?
Old Apr 26, 2005 | 03:32 PM
Luserkid's Avatar
Depending on what kit you get they might just give you the washer. Unless if you get the adjustible upper control arms (dont come with basic camber kits).
The way the washers work is they push the upper control arm to give you postive camber. You put the washer on the bolts UNDER the upper control arm.
Old Apr 26, 2005 | 03:35 PM
Turbo_y8's Avatar
you can do the rear for much cheaper, just take one of the bolts that bolts into you frame, get a litle bit longer bolt bolt and pick up like 20 washers or or however many you think you might need depending you on your drop im dropped 3.5 inchs all around and i used 5 washers on each trailing arm bolt and its alot better, still a little neg. compared to my front which is less than a 1/4 degree off and my back is prolly about a full degree off it looks good all around tho, i used the omnipower camber kit for the front
Old Apr 26, 2005 | 03:48 PM
pgpunkguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">...You put the washer on the bolts UNDER the upper control arm. </TD></TR></TABLE>
i forgot that the first time i did it years back... and i wondered why my camber didn't change with 5 washers...
JDMCRX
Suspension & Brakes
10
Apr 11, 2013 04:57 AM
ChevelleSSLS6
Mar 10, 2009 01:05 PM
Maxboost808
Jul 16, 2004 02:42 PM
..::91TEG-G2::..
May 23, 2004 01:53 PM
Todd00
Jul 3, 2002 09:48 AM
