ls or gsr block?
Old Apr 26, 2005 | 03:16 PM
arielmalespin's Avatar
Default ls or gsr block?
guys im a little confused right now, i dont know wat block to use either the ls or gsr block. my friend told me get and ls block and throw a gsr crank, gsr bearing, ls rods and the pistons i wanna use whick are ctr. but for that dont u think is better if i get a gsr block, i heard the ls block is stronger then the gsr. but do u think i should get a gsr block and some ls rods witht the ctr pistons?
Im completely lost guys. also im plannin to use a b16a head. Any opinions will be fully appreaciated.
Old Apr 26, 2005 | 04:24 PM
pgpunkguy's Avatar
Default Re: ls or gsr block? (arielmalespin)
are you gonna be boosting or not?
both are pretty strong
Old Apr 26, 2005 | 04:57 PM
Default Re: ls or gsr block? (pgpunkguy)
no im going all motor but i wanna get around 200whp if that helps
Old Apr 26, 2005 | 06:09 PM
pgpunkguy's Avatar
i think either would be fine...
gsr block will be less work if using vtec head.
Old Apr 26, 2005 | 08:56 PM
notstock93's Avatar
Ive got an LS block for sale
But a GSR block would be easier.
Old Apr 27, 2005 | 05:58 AM
95lstegman's Avatar
Default Re: ls or gsr block? (notstock93)
a GSR block won't need to be built to make 200whp NA. they rev better forever. LSs rev fine, and then a bearing spins. bye-bye high-revving LS. get a GSR shortblock if you can. don't bother putting GSR internals into an LS block. r/s ratio is almost the same, and you lose the one main advantage the GSR has, which is its main cap girdle.
Old Apr 27, 2005 | 08:46 AM
Default Re: ls or gsr block? (95lstegman)
ok, but them why people that go all motor build ls/vtec and not gsrblock/b16a head? is it cuz of the price? and also let say i decided to go with a gsr block for how much u think they go for just the block?
Old Apr 27, 2005 | 09:59 AM
95lstegman's Avatar
$1k for a nice short-block, as low as $500 for okay used one. yes, they do it b/c LS is cheaper, and b/c they think the 34cc larger LS will be faster. it's a little faster thanks to longer crank, but if you rev higher and put large cams i think it would be a moot point, and at 9000rpm might be a pretty bad thing. GSR would definitely be more reliable. i mean, honda spins them to 8500 bone stock. mugen and spoon spin them to 9000 bone stock.
Old Apr 27, 2005 | 11:24 AM
mrDFWmechanic's Avatar
i'd go for the gsr block if your going all motor
russianswty
Oct 17, 2006 03:09 PM
kcjohnnyboy
Feb 15, 2006 06:35 PM
EK FLY
Jan 4, 2006 06:17 PM
LBDM EK97
12
Apr 12, 2005 03:58 PM
