Clutch pedal pressure increase?
Well this happened awhile ago but I haven't had the time to look at it yet. Basically my clutch pedal has gotten a lot stiffer to push in. I've had the same setup untouched for 3 years before this happened. It just started one day in traffic and it drives fine but just is alot harder to push in. I'm thinking bleed the slave cylinder and master w/ new fluid. I've inspected the clutch fork and from what I can see everything looks okay. If new fluid doesn't work I guess I'll have to drop the tranny and see about the throwout bearing. Anyone have this problem before?
Brian
Brian
this happend on my friends 4 door when his main bearing went out in the tranny. im not saying thats your problem but when i put his new tranny on with new clutch kit it was alot easyer to push down. maybe try greasing the shaft that the throw out bearing slides on.
my cluth pedal does the same thing....except it goes back and fourth....for a while it will be stiffer than normal then it will change back to normal easy flow pressure. Does this mean my pressure plate is on the way to being faulty? or is it faulty now?
BolivianDc2
Jan 20, 2007 09:10 AM
Nextelbuddy
12
Jul 14, 2003 11:34 PM
