Welding Aluiminized steel
Old Apr 26, 2005 | 01:05 PM
RCautoworks's Avatar
Default Welding Aluiminized steel
This can be done with a mig correct ? Do I need to grind away at the coating first ? And not in breath the fumes right, am I missing anything else ?
Old Apr 26, 2005 | 10:00 PM
Default Re: Welding Aluiminized steel (90blackcrx)
Anyone ?
Old Apr 26, 2005 | 10:02 PM
CRXDrew's Avatar
u can weld it w/ mig. Just clean it as usual. Brush it a few times whatever.
Default Re: (CRXDrew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXDrew &raquo;</TD></TR><TR><TD CLASS="quote">u can weld it w/ mig. Just clean it as usual. Brush it a few times whatever.</TD></TR></TABLE>
Thanks, I thought so but I just wanted to make sure.
Old Apr 26, 2005 | 10:07 PM
CRXDrew's Avatar
Heh, no prob. If you couldn't I sure proved everyone wrong w/ my downpipe.
Old Apr 26, 2005 | 10:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXDrew &raquo;</TD></TR><TR><TD CLASS="quote">Heh, no prob. If you couldn't I sure proved everyone wrong w/ my downpipe. </TD></TR></TABLE>
Well I did not know if you had to grind the coating away.
Old Apr 27, 2005 | 06:07 AM
TurboMiata's Avatar
Default Re: (90blackcrx)
you dont *have* to grind the coating away. I've welded lots of it without removing the coating. It sure welds alot better when you do though...
Old Apr 27, 2005 | 07:49 AM
5STAR3's Avatar
Default Re: (TurboMiata)
PLEASE weld it out side.
Old Apr 27, 2005 | 07:52 AM
90DALS's Avatar
i mainly use a wire brush to get it off. if you weld it with the coat still on, do it out side. if not, the gasses will get under you mask, and irritate your skin. makes yoru skin feel "sun burned" and makes you get bags under your eyes. so do it outside.
Old Apr 27, 2005 | 08:24 AM
AspectIndustries's Avatar
Default Re: (90DALS)
It will weld, most definately. For tig, you will have to grind that sucker down.
But Mig, yes, weld it, but do it outside or in a nicely vent area.
Old Apr 29, 2005 | 10:46 PM
Brandon Clifton's Avatar
If every Jim-Bob and Billy-Ray that works at an exhaust shop can do it, surely you can do it!
Old Apr 30, 2005 | 09:32 AM
Default Re: Welding Aluiminized steel (Brandon Clifton)
I'll just grind the coating off. But will I be able to tell when the coating is all off ? I mean is it visible ?
Old Apr 30, 2005 | 10:11 AM
The coating is less than .001" thick. Just turn the amps up and burn through it.
If you INSIST on removing it, just use some 80-grit sand paper, wrap around the pipe, grasp your hand around it, and turn the pipe back and forth a few times.
Old Apr 30, 2005 | 10:27 AM
Well I can't really weld it outside so I have to take the coating off
Old May 1, 2005 | 10:06 AM
Just Checking In's Avatar
Clifton is correct. If you clean your work with a wire brush anyways you will take the aluminum silicon coating doing that alone. This isn't a galvanized pipe which would make a mess and excessive harmful fumes.
hip_hop_s0ulchild
Sep 19, 2007 05:44 PM
localev
Jan 22, 2006 05:44 PM
Toda Party
Jan 24, 2005 01:59 AM
lanceh
Oct 9, 2004 05:34 AM
