Suspension & Brakes Theory, alignment, spring rates....
The dreaded broken rear Lca bolt through strut on 98 civic info for those who don't know
Old Apr 26, 2005 | 12:26 PM
ismellskunk's Avatar
Default The dreaded broken rear Lca bolt through strut on 98 civic info for those who don't know
well i recently bought a 98 civic ex and the first mod i did was skunk 2 coilovers all the way around started on the rear passenger side took off the tire used the air gun and "crack" the bolt head snapped off so i had to cut the strut off then soaked the bolt in liquid wrench i tried beating the bolt out at first and the bushing was flexing therefore no progress then i got smart and used a hammer to hold one side and hammered on the otherside finally breaking it free probably not a good tech thread but i tried and it helped me and may do the same for you as well sorry i wasnt thinking and didnt take pics!!
Old May 1, 2005 | 12:48 PM
matt7277's Avatar
Default Re: The dreaded broken rear Lca bolt through strut on 98 civic info for those who don't know (ismell
hey this exact thing happend to me yesterday except i'm putting springs on. How the hell are you suppose to get that bolt out? have any pictures?
Old May 1, 2005 | 03:04 PM
95LSDOHC's Avatar
this happened to me awhile back when lowering my teg...i ended up having to drill it out. I tried prob everything else before i drilled it and none of the ideas worked.
To save time and patience i would just say drill that sucker right out
Old May 3, 2005 | 08:23 AM
matt7277's Avatar
well i ordered some KYB GR-2's for the rear and i'm gonna try putting those on along with the springs now. hopefully i can get the old strut off though. i may end up just hacking it in half! lol
Old May 3, 2005 | 09:22 AM
94eg!'s Avatar
#1 Super Guy
Loved
Anti-seize is your friend on all the LCA bolts...
Old May 4, 2005 | 08:05 AM
93b16's Avatar
well if you keeping the same shocks just take the whole lca off. If not good luck might as well have the bushing pressed out and a new one put in
Old May 9, 2005 | 02:55 AM
matt7277's Avatar
Default Re: (93b16)
well i just went through this and what i ended up having to do was to take the strut off, then to use a high power torch to blast out some of the bolt and then just slam on the long end with a hammer until the bushing and the bolt came right out (the heat kinda melted the bushing up, but just a tiny bit to the point where it was soft and could pop out). Well then it was easy to just bang the bolt out of the bushing and then reinsert the bushing, new bolt, and strut. now all is good with my setup! KYB gr-2 Rear Struts with Neuspeed racing springs
Old May 9, 2005 | 06:16 AM
iakona's Avatar
why no new bushing?
Old May 9, 2005 | 08:26 AM
matt7277's Avatar
the old one was still good. just melted a tiny tiny bit at the end where the bolt was blasted out. Lubed it up with some greese and popped it back in. good as new
dorian7
Sep 9, 2013 11:35 AM
EG6KILIN
Aug 8, 2009 04:31 PM
turbotime
May 3, 2007 09:49 PM
TheHatchHog
10
Jul 29, 2004 07:15 AM
haccord2.2
Jul 10, 2003 07:34 AM
