Searched: possible FAQ B series alternator and belt ef
FAQ:
So you are enjoying your ef b series powered hatch for a while and uh oh your alternator dies. If you have Hasport mounts, I do not know about the other companies, the alternator you need is from a 90-91 integra, and it's respective belt. I bought one shorter along with the integra belt, but the shorter one wasn't needed.
Removal/Installation: Don't even bother trying to take the alternator out from up top, unless you want to remove your MC or brake booster. NO matter how close it came, I could not remove the alternator from up top.
SAVE YOURSELF SOME TIME AND ....take out the intermediate shaft like you know you're supposed to do from the start
It comes out like buttah after that.
Modified by B16_madman at 12:59 AM 4/28/2005
.It comes out like buttah after that.
I ran into a big problem with doing my swap. My alt. from my d-series was modified so I could run a larger stereo system. I went to go and put the d-series alt. in and it won't fit. Then I try and put the old b-series alt. in and that won't fit either.
My main concern is when I want to run the stereo I need the d-series alt. due to the fact that it was built to put out more than the standard d-series alt. I tried switching the pullies but one is larger than the other and won't let the pully spin freely.
Any suggestions other than get a new alt. built, I paid almost $400 for the built d-series alt.
better to just use the b series alt. there are several issue with using mix matching since they mount diffrent, and have diff size pulleys.
AllMotaEF9
Oct 12, 2006 06:06 PM
DXDOHCVTEC
Sep 1, 2003 12:06 AM
