Overheating on hot days??
Old Apr 26, 2005 | 11:19 AM
technine's Avatar
Default Overheating on hot days??
My girls EK overheats on hot days it seems only. Cold days seem fine. There are no mods to the car accept I hooked the radiator fan to come on when the car comes on due to it not coming on ever (relay problem I guess). So the fan runs constantly and she still overheats.
When this happens I tell her to turn the heater on full blast and the temp gauge goes to half way or a little under. I bled the system 2 times, I'm pretty sure there is no air at all. Coolant looks fine, no water shooting out of reseviour either, doesn't boil over, no signs of leaking, I'm stumped.
So the main symptoms are, car overheats on hot days, turn on the heater and goes back to normal or close to normal. Anyone know what this could be? TIA
Old Apr 26, 2005 | 01:21 PM
SiFan's Avatar
Default Re: Overheating on hot days?? (technine)
thermostat?
Old Apr 26, 2005 | 01:22 PM
sadangryboi's Avatar
maybe ur thermostat is messed up
Old Apr 26, 2005 | 01:26 PM
AZMyst's Avatar
Default Re: (sadangryboi)
I would bet it's your thermostat. I have a 90 Accord for a daily driver and it started doing the exact same thing. Changed the thermostat, completely flushed the rad/block, refilled, and no more overheating.
Old Apr 26, 2005 | 01:29 PM
EVIL Hx Coupe's Avatar
Default Re: (AZMyst)
Your thermostat is sticking closed.
Old Apr 26, 2005 | 01:31 PM
dso's Avatar
dso
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiFan &raquo;</TD></TR><TR><TD CLASS="quote">thermostat</TD></TR></TABLE>
Old Apr 26, 2005 | 01:35 PM
greenblurr93's Avatar
I had the same problem, changed my thermostat and flushed the cooling system and nothing... as it turned out my radiator was clogged and not letting the proper amount of collant flow... so i bought a PWR Aluminum radiator...
Old Apr 26, 2005 | 02:14 PM
Turbo E's Avatar
for the last time...thermostat.
a good way to check without opening the housing up is feel the lower rad hose. if its cold and the upper is hot, the thermo is dead.
Old Apr 26, 2005 | 02:17 PM
H.A.R.T B18C1EG6's Avatar
Default Re: (Turbo E)
good chance it is the thermostat..... and make sure the fan on the radiator turns on
Old Apr 26, 2005 | 02:24 PM
Default Re: (H.A.R.T B18C1EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.A.R.T B18C1EG6 &raquo;</TD></TR><TR><TD CLASS="quote">good chance it is the thermostat..... and make sure the fan on the radiator turns on</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by technine &raquo;</TD></TR><TR><TD CLASS="quote">I hooked the radiator fan to come on when the car comes on due to it not coming on ever (relay problem I guess). So the fan runs constantly and she still overheats. </TD></TR></TABLE>
Old Apr 26, 2005 | 02:25 PM
modedicebox's Avatar
if i was a betting man id say it was the thermostat
Old Apr 26, 2005 | 02:27 PM
technine's Avatar
The bottom is warm and the upper is hot. Should they be close to the same temp? Or should it be a little colder because of the heat transfer?
I can keep my hand on the bottom forever, but the top will get pretty hot.
Old Apr 26, 2005 | 03:51 PM
technine's Avatar
So what temp should the thermostat open at?
Old Apr 26, 2005 | 04:40 PM
pgpunkguy's Avatar
depends on the car...
i think full open is 195*F on my civic (i think)
i would first make sure the fan is turning on...
then i would first replace the thermostat (quick and relatively cheap)
then i would take my radiator to a radiator shop to get acid dipped because it is probably clogged...
Old Apr 26, 2005 | 04:44 PM
technine's Avatar
Default Re: Overheating on hot days?? (pgpunkguy)
Well, FAN IS ALWAYS ON as stated in the first post.
What about radiator cap? Can this cause this also? If I replace the thermostat, I will also replace the radiator cap as well because both are cheap and easy.
Aslo when I was bleeding the system I put a radiator filler funnel (big neck) and filled it with water to the top, reved the motor and fluid started to fill up the funnel as I reved and dropped back down. Is this normal?
Old Apr 26, 2005 | 06:13 PM
pgpunkguy's Avatar
yes, radiator cap can also be a problem...
if you noticing the coolant overflow tank being filled and never returning to radiator, then your radiator cap is bad or there is a leak in the hose between radiator and overflow tank.
Old Apr 26, 2005 | 07:13 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: (technine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by technine &raquo;</TD></TR><TR><TD CLASS="quote">The bottom is warm and the upper is hot. Should they be close to the same temp? Or should it be a little colder because of the heat transfer?
I can keep my hand on the bottom forever, but the top will get pretty hot. </TD></TR></TABLE>
the upper should be cooler than the lower. r e p l a c e t h e t h e r m o s t a t e
Old Apr 26, 2005 | 07:33 PM
chad's Avatar
Moderator
Default Re: (95DxSi-R2)
SEARCH!!!!!!!!
under my name....i made a checklist!
Old Apr 28, 2005 | 03:43 PM
technine's Avatar
Default Re: (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">SEARCH!!!!!!!!
under my name....i made a checklist!</TD></TR></TABLE>
Did it under your name, nothing came up!!!!!!
Can you somehow help me Chad?
Old Apr 28, 2005 | 04:21 PM
pgpunkguy's Avatar
so you changed your thermostat and still have problems?
Old Apr 28, 2005 | 05:36 PM
technine's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 &raquo;</TD></TR><TR><TD CLASS="quote">
the upper should be cooler than the lower. r e p l a c e t h e t h e r m o s t a t e</TD></TR></TABLE>
Upper cooler?? Is that where the coolant goes into the head and the bottom is the return line?
technine's Avatar
Default Re: (pgpunkguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgpunkguy &raquo;</TD></TR><TR><TD CLASS="quote">so you changed your thermostat and still have problems?</TD></TR></TABLE>
Sorry, gonna do that this weekend along with the cap. I'll keep you guys updated. Thanks everyone!
Old May 9, 2005 | 12:47 PM
technine's Avatar
Changed the thermostat and radiator cap. My girl is driving it for the first time today so we'll see what happens. I also bled the system for 4-5 fan cycles and hooked the fan up the right way (relay seems to be working so no more fan on all the time).
I'll let you know what happens.
simplegreenmachine
13
Dec 12, 2009 04:07 PM
vlude99
Jul 30, 2009 05:58 PM
meanshyguy
Aug 24, 2008 07:50 AM
yz125rider21
11
Aug 9, 2006 04:42 PM
ZC88CRX
Sep 2, 2003 09:57 AM
