ZC Head Stud Torque.
Old Apr 26, 2005 | 09:20 AM
Blindstuff's Avatar
Default ZC Head Stud Torque.
I figured this would be the best place to ask about a DOHC ZC so, i pulled out the cams, and its time to put them back in, i need to know up to what to tighten them, and same thing for the valve cover, i always brake the gasket .
Any help would be apreciated, i tried searching but "ZC" is to short to include in the query.
Old Apr 26, 2005 | 01:35 PM
clsmooth's Avatar
Default Re: ZC Head Stud Torque. (Blindstuff)
I believe the cam cap bolt are 9 inch-lbs, very little. Valve cover, hand tight.
Old Apr 26, 2005 | 03:04 PM
Blindstuff's Avatar
Default Re: ZC Head Stud Torque. (clsmooth)
Thanx. Any other input?
Old Apr 26, 2005 | 04:44 PM
Blindstuff's Avatar
*Bump*
Old Apr 26, 2005 | 04:57 PM
SwissChEz82's Avatar
http://www.thzcr.com
Old Apr 26, 2005 | 07:12 PM
Blindstuff's Avatar
Default Re: ZC Head Stud Torque. (SwissChEz82)
Link is dead, anyone else?
Old Apr 26, 2005 | 08:08 PM
jlicrx's Avatar
camshaft caps - 9 ft lb
valve cover - 7 ft lb
link should be:
http://www.thezcr.com
Old Apr 27, 2005 | 09:23 AM
Blindstuff's Avatar
Default Re: ZC Head Stud Torque. (jlicrx)
Found it, for factory head studs its 48 ft/lbs.
Thanx a lot everyone
90si-rex
Sep 13, 2009 09:29 PM
GregEF
Jan 16, 2008 12:31 AM
91ZCsi
Feb 22, 2005 11:37 PM
