Suspension & Brakes Theory, alignment, spring rates....
Bolt Size For OEM Front Strut Bar
Old Apr 26, 2005 | 07:52 AM
oc_civic's Avatar
Default Bolt Size For OEM Front Strut Bar
i got a honda access optional front strut bar from marcus at heel toe, he gave me a good deal because it came without hardware... its the type of bar that you drill through the divits on each side (by the front struts) what size bolts do i need to get? thanks...
Old Apr 26, 2005 | 11:38 AM
dfoxengr's Avatar
Default Re: Bolt Size For OEM Front Strut Bar (oc_civic)
do you havea centimeter ruler wil mm increments?
and is anything already threaded on the bar, or do you need bolts and nuts?
Old Apr 26, 2005 | 03:16 PM
oc_civic's Avatar
Default Re: Bolt Size For OEM Front Strut Bar (hybridvteceg)
nuts and bolts.. mostly looking for length...
Old Apr 26, 2005 | 03:42 PM
dfoxengr's Avatar
you cant measure it?
maybe like 30mm, 12x1.50 thread. that should be good
simple and you can get them at lowe's
ShadowTeg
Feb 5, 2012 05:31 PM
gsrclan
Oct 16, 2009 11:17 PM
dtt02278
Apr 18, 2009 03:33 PM
Understeer
Apr 24, 2003 11:41 AM
civicboi950
Dec 20, 2001 09:11 PM
