Questions regarding valve adjustment - using torque wrench
Old Apr 26, 2005 | 06:09 AM
vtec.dc2's Avatar
Default Questions regarding valve adjustment - using torque wrench
1. Helms says to retorque to 14 lbs/ft, so is it o.k. to use 3/8" craftsman wrench? i do that for spark plugs and they're 13 lbs/ft, but these bolts seems much smaller i don't want to break anything
2. Helms say to retorque crank pulley bolt. Is that necessary?
Old Apr 26, 2005 | 06:26 AM
RTW DC2R's Avatar
If you dont loosen the crank pulley bolt, I dont see a need to tighten it again.
I never understood how to go about torquing the valve train bolts because you need to hold the valve in place with the flathead. I just guesstimate by torquing another bolt to 14ft/lbs to get an idea how much to tighten it :shrugs:
Old Apr 26, 2005 | 06:30 AM
vtec.dc2's Avatar
Default Re: (RTW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW &raquo;</TD></TR><TR><TD CLASS="quote">If you dont loosen the crank pulley bolt, I dont see a need to tighten it again.
I never understood how to go about torquing the valve train bolts because you need to hold the valve in place with the flathead. I just guesstimate by torquing another bolt to 14ft/lbs to get an idea how much to tighten it :shrugs:</TD></TR></TABLE>
i thought you only need to hold it in place until the locknut is tight enough, then you could recheck with torque wrench? does that sound right?
Old Apr 26, 2005 | 06:39 AM
RTW DC2R's Avatar
possibly...but for whatever reason even if my lock nut is snug on some valves, when I torque it down, the valve still moves and I need the flat head to hold it in place. only happens on some of the valves though. dunno why.
Old Apr 26, 2005 | 07:20 AM
splitime's Avatar
Default Re: (RTW)
I just redid a valve adjustment yesterday. And for the first time torqued them.. I found that going fairly handtight with the box wrench while holding the screwdriver works... then go back with the TQ wrench. Then double check with feeler gauges. Then... move on.
Old Apr 26, 2005 | 07:25 AM
Black R's Avatar
25 Year Member
Default Re: (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">I just redid a valve adjustment yesterday. And for the first time torqued them.. I found that going fairly handtight with the box wrench while holding the screwdriver works... then go back with the TQ wrench. Then double check with feeler gauges. Then... move on.</TD></TR></TABLE>
.....that's what I always do. I don't trust hand tight to keep the locking nutz from coming loose and letting the valve fly south.....
Old Apr 26, 2005 | 07:34 AM
pyromaster's Avatar
Default Re: (RTW)
I have the same issue. After tightening them handtight with the snap-on tool and then torqueing them the valves were always too tight. I specifically remmebre intake valves on cyl 1 being like this for me. After trying a few times with the same result, eventually I just did them hand tight and moved on. Glad I'm not the only one
Old Apr 26, 2005 | 07:58 AM
vtec.dc2's Avatar
what size torque wrench do you use? is 3/8" too big?
Old Apr 26, 2005 | 08:01 AM
splitime's Avatar
Default Re: (vtec.dc2)
No torque wrench is too big if you have a socket that fits. Since they will all torque to the amount you set them.
Old Apr 26, 2005 | 08:17 AM
SecretAgent's Avatar
yeah, but the smaller the torque wrench the better. the larger ones aren't very accurate at their lowest torque settings. a 3/8 ft lb'r or a 3/8 in lb'r would be best.
civicdelsol33
May 5, 2008 03:09 PM
D16SohcVtec
Nov 8, 2007 03:04 PM
whitenameseboi
Mar 25, 2005 02:47 PM
Rtzx9r
Apr 7, 2003 11:54 PM
JeffS
Feb 28, 2002 09:49 AM
