Bridgestone Fusions
Old Apr 26, 2005 | 05:57 AM
delsol93guy's Avatar
Default Bridgestone Fusions
Does anyone have these... how do they hold up? Is this a good tire to put on 17" Rims?? Let me know what you know!
Thanks Guys
Old Apr 26, 2005 | 02:59 PM
Default Re: Bridgestone Fusions (delsol93guy)
bump
Old Apr 27, 2005 | 06:57 AM
nsxtasy's Avatar
H-T Order of Merit
The Fuzion (that's how it's spelled) brand, which is made by Bridgestone but marketed as its own brand name, is new on the market, so it might be tough getting actual experience reports on them, particularly for wear (which takes a while) and for a larger wheel size than most of us are using. The Fuzion ZRi did well in Tire Rack testing, though...
Old Apr 27, 2005 | 09:13 AM
Default Re: Bridgestone Fusions (nsxtasy)
Thanks for the reply, So do you think i should look into different ones or is this something i might want to try and run on??? It is a low profile tuner tire correct??
Thanks again!
Old Apr 27, 2005 | 09:25 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsol93guy &raquo;</TD></TR><TR><TD CLASS="quote">So do you think i should look into different ones or is this something i might want to try and run on???</TD></TR></TABLE>
Sure. They were tested by the Tire Rack against the Avon Tech M500 and the Yokohama AVS ES100. All did well, and all are fairly inexpensive. The ES100 is a fairly well-known tire; you can find lots of reports on them. The Avon and Fuzion are both new to the market, so you'll be among the first to try them. Based on the test results, it sounds like either one is worth trying.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsol93guy &raquo;</TD></TR><TR><TD CLASS="quote">It is a low profile tuner tire correct??</TD></TR></TABLE>
Well, the profile is the same as any other tire in that size. As far as being a "tuner" tire, I think that's just marketing hype - like the two cartoon characters...
Old Apr 27, 2005 | 09:33 AM
Thanks.... anybody elses opinion is always considered!!!
Old Apr 27, 2005 | 03:37 PM
HXMan's Avatar
I just got some fuzion Hri's on the 14" steelies on my miata...they are good tires for the price($39 ea).
I have seen the Zri's at work and they are definatly more agressive then the Hri's but they are summer only tires.
Old Apr 27, 2005 | 04:40 PM
Thirty-Nine's Avatar
Default Re: Bridgestone Fusions (HXMan)
IM "phatsi" he has them.
Old Apr 28, 2005 | 05:38 PM
wannabe_si's Avatar
Default Re: Bridgestone Fusions (Sushiboy)
the zri is a decent dry handeling tire but it isnt that great in wet weather
they arent that loud and have decent tread life
and they are fairly cheap considering other options
xkrntamax
Jul 12, 2007 08:52 PM
hypeR_ash
Mar 21, 2007 07:44 PM
texx
Honda S2000
Apr 12, 2006 11:39 AM
ImXposed
Dec 4, 2005 09:42 AM
Turbo92Si
May 4, 2004 08:58 AM
