Cx wiring diagram
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonef »</TD></TR><TR><TD CLASS="quote">Oka heres the situation a customer put a vx motor into his cx so i need the wiring diagram from the shock towers to the ecu sorry.</TD></TR></TABLE>
The diagram is going to look like that. I have it, I will post it in a bit.
if you can understand it... I did a wire swap guide for a D15Z1(VX) into a Dx using the DX chassis harness and the VX engine harness and VX(P07) ECU.
http://www.b18c5eg.com/itr_vx_wiring.html
you'll have to also add the A6-C103-2 wire for heater control.
4 years later can i bump this? i would like to see a cx wiring diagram as well from the dash to the ecu possibly color coded. That would be ideal.
