difference in vtec solenoid? obd0/obd1/obd2?
Old Apr 25, 2005 | 11:46 PM
ceLtic*
Guest
Posts: n/a
Default difference in vtec solenoid? obd0/obd1/obd2?
i have an ls/vtec with a jdm b16 obd0 head. my question is are all vtec solenoids the same, or are there differences between obd0/obd1/obd2?
reason i ask is because i am getting a code 21 and i've searched with no clear answer as to what i can do to eliminate this code. [vtec solenoid valve]
Old Apr 26, 2005 | 12:32 AM
hahagasdcrx's Avatar
Default Re: difference in vtec solenoid? obd0/obd1/obd2? (ceLtic!)
might not be hooked up correctly ( loose wire, not in the right ecu pin location, damaged wire grounding out ).
Your screen might be clogged as well.
mark11017
Mar 19, 2010 12:38 PM
vtizzle
Engine Management and Tuning
Apr 23, 2009 12:04 AM
ELABR8
Feb 16, 2005 02:46 PM
URNVS
Jun 22, 2004 10:35 PM
