Gsr swap+96 hatch=pain in the ass!
Old Apr 25, 2005 | 07:43 PM
hulk252's Avatar
Default Gsr swap+96 hatch=pain in the ***!
Just venting a little frustration. Got my swap bolted in and now the bitch won't fire up. Turns over and has a dim check engine light? What the hell is that. Light goes out but is dim at first turn? I even have a genuine honda technician leading the swap. Ohh well, tomorrow is another day with more sunlight.
Old Apr 25, 2005 | 11:24 PM
Hybrid96EK's Avatar
Default Re: Gsr swap+96 hatch=pain in the ***! (hulk252)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hulk252 &raquo;</TD></TR><TR><TD CLASS="quote">Just venting a little frustration. Got my swap bolted in and now the bitch won't fire up. Turns over and has a dim check engine light? What the hell is that. Light goes out but is dim at first turn? I even have a genuine honda technician leading the swap. Ohh well, tomorrow is another day with more sunlight. </TD></TR></TABLE>
Most not be to "genuine" if they can't solve the problem. Once the light comes on from cranking, does it stay on?
Old Apr 26, 2005 | 02:59 AM
Spoon Si's Avatar
Default Re: Gsr swap+96 hatch=pain in the ***! (Hybrid93Eg)
Kinda Funny, Sounds a little like my situation.
Check to see if you have your cable grounded from the tranny side.
Old Apr 26, 2005 | 06:48 AM
foonk's Avatar
that sucks, but soon youll have a gsr motor.
Old Apr 26, 2005 | 02:21 PM
TurboCivicEX's Avatar
fixed!!!! it was a loose ground at the thermostat housing....
next problem......the tach. doesn't work? and the IACV isn't doing anything...code 65....Idle is low, I unpluged it to set base idle and the idle didn't drop?
Old Apr 26, 2005 | 02:46 PM
Hybrid96EK's Avatar
Default Re: (TurboCivicEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboCivicEX &raquo;</TD></TR><TR><TD CLASS="quote">fixed!!!! it was a loose ground at the thermostat housing....
next problem......the tach. doesn't work? and the IACV isn't doing anything...code 65....Idle is low, I unpluged it to set base idle and the idle didn't drop?</TD></TR></TABLE>
Tach pickup is in the dist.. I would say to check to make sure no loose connections there. Code 65 is the secondary O2. did you even hook this up?
Old Apr 27, 2005 | 04:41 AM
sorry code 14....and no there is no secondary o2, we will be installing hodata next week.
Old Apr 27, 2005 | 12:15 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboCivicEX &raquo;</TD></TR><TR><TD CLASS="quote">sorry code 14....and no there is no secondary o2, we will be installing hodata next week.</TD></TR></TABLE>
I'd say you either have the wrong thing plugged into the IACV or you still have a wiring issue and possibly a bad ground linked to that circuit. I've never seen a bad IACV either, so I don't know if it would cause it to toss a code. I am pretty sure it would since its nothing more then a solenoid... I would say to try swapping IACV's first, if you still have same problem, check the connector to make sure its the right one, then investigate possible ground/wiring issues.
eascencio84
Jul 17, 2011 04:16 PM
yeahyeah1469
Oct 2, 2010 01:04 AM
marinersfaninmd
Acura TSX
Jun 15, 2009 07:24 PM
blinger
Apr 27, 2007 07:48 PM
H22A EG6
Feb 22, 2004 03:56 AM
