Accord 1990 - Stop/horn fuse blows when horn is used
Old Apr 25, 2005 | 06:44 PM
da_twiy's Avatar
Default Accord 1990 - Stop/horn fuse blows when horn is used
When that fuse is blown, I can't shift the auto transmission away from park. Can anyone tell me why using the horn does this? In the past, I did not have problems with the horn. Thanks.
Old Apr 25, 2005 | 06:49 PM
yellowdcn's Avatar
Default Re: Accord 1990 - Stop/horn fuse blows when horn is used (da_twiy)
you have an exposed wire somewhere
i had the same problem 2 months ago, my spoiler taillight wire were exposed and touching metal and everytime i honked/hit the break, my fuse would blow.
Old Apr 25, 2005 | 06:55 PM
da_twiy's Avatar
Default Re: Accord 1990 - Stop/horn fuse blows when horn is used (yellowdcn)
how should i go about determining where the wire is exposed
Old Apr 25, 2005 | 07:25 PM
deserthonda's Avatar
this is if fuse only blows when you push horn buttin...... the brake and horn system share the same fuse so if it blows, the brake switch cannot activate the shift interlock solenoid thus you cannot get car out of park ,, it fuse blows when you apply horn ,find where the horns are and unplug them i have seen horn short internally , once disconnected put a fuse and push on the horn button it won't toot but if fuse does not blow the horns are faulty if it still blows fuse you got a short on the horn system ,,
Old Apr 26, 2005 | 06:57 AM
jweller's Avatar
Default Re: (deserthonda)
you need a "Horn broken, watch for finger" bumper sticker
definatly a short somewhere, you'll hae to use a multimeter and start tracing wires. no other way to find it.
87integra
Apr 24, 2018 09:07 PM
jasrams
Honda Civic (2001 - 2005)
Jul 10, 2012 12:13 PM
CheddarPopcorn
Jun 30, 2009 10:53 AM
Sic_DA_Nine
Audio / Security / Video
Jan 7, 2007 11:04 AM
