milled head question
Old Apr 25, 2005 | 05:48 PM
racekar's Avatar
Default milled head question
if my head is milled does my distributor need to be advanced?
thanks
Old Apr 25, 2005 | 06:21 PM
racekar's Avatar
anyone
Old Apr 25, 2005 | 06:36 PM
zman's Avatar
Default Re: (racekar)
if you mill it .030" your timing will be off by -2 degrees, so set your cam gears to +2 to true them. So, by advancing the intake cam gear you will be advancing the dizzy too....so i guess if you want your ignition timing to be at OE specs then you would need to advance it a little bit....b/c if your cams are retarded 2 degrees then your dizzy is too b/c its attached to the intake cam.
Old Apr 25, 2005 | 07:08 PM
frozenb's Avatar
Default Re: (zman)
i hv a q uestion too. i hv a h22a, so the dizzy is on the exhaust cam..i mill my head like 35 thou..and my cam gear is set to 0 now..i use timming gun to check my timming and it's 17 degree on idle...is it correct or i need to move my cam gear..cuz the car seems slow. i hv stage 2 cam
Old Apr 25, 2005 | 07:16 PM
Kendall's Avatar
Default Re: (frozenb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frozenb &raquo;</TD></TR><TR><TD CLASS="quote">i hv a q uestion too. i hv a h22a, so the dizzy is on the exhaust cam..i mill my head like 35 thou..and my cam gear is set to 0 now..i use timming gun to check my timming and it's 17 degree on idle...is it correct or i need to move my cam gear..cuz the car seems slow. i hv stage 2 cam </TD></TR></TABLE>
Advance your cams 2 degrees, then play with the dizzy. 17 is correct though.
Old Apr 25, 2005 | 07:40 PM
frozenb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Advance your cams 2 degrees, then play with the dizzy. </TD></TR></TABLE>
u mean i advance my intake or exhaust cam???
i beleive u talking about exhaust cam, rite??
Old Apr 25, 2005 | 08:00 PM
racekar's Avatar
how about if i have stock cam gears.. can i just advance my dizzy?
Old Apr 25, 2005 | 08:13 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Advance your cams 2 degrees, then play with the dizzy. 17 is correct though.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frozenb &raquo;</TD></TR><TR><TD CLASS="quote">u mean i advance my intake or exhaust cam??? </TD></TR></TABLE>
CamS as in two of them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racekar &raquo;</TD></TR><TR><TD CLASS="quote">how about if i have stock cam gears.. can i just advance my dizzy?</TD></TR></TABLE>
Your cam timing still won't be correct and odds are it'll have more of an effect on power than will two degrees of ignition timing.
Old Apr 25, 2005 | 08:19 PM
frozenb's Avatar
oh..i miss that.. ha
thx man.. i will try tomorrow then
Bevin
Sep 19, 2006 11:01 PM
Griffin@Camtech
Oct 6, 2005 07:08 PM
sik_sol
Apr 2, 2005 12:52 PM
JDMs1eeper
18
Aug 24, 2003 12:01 AM
WICKED2
Jul 31, 2002 10:22 AM
