Custom length ignition wire set
Ok, I'm running an Electromotive direct ignition with the module/coils mounted about where the stock air-box used to be and need to find a universal wire kit with Honda boots. To top it all off, the Electromotive connectors seem to be some sorta GM 90-deg boots. Ideally, i'd like to find a custom wire kit that would have the Honda plug boots installed and the other end naked so that I can cut it to required length and fit the appropriate boot.
Any ideas on who makes something like this?
BTW, another related question. Are all Honda plug-end boots the same between different years/engine series? ie Ds, Bs, Hs etc?
Thanks.
Thanks.
