tigging v band flange right to exh housing??
Old Apr 25, 2005 | 04:59 PM
hotrex's Avatar
Default tigging v band flange right to exh housing??
i take my dp off so damn much im going v band. my question is this, can i tig the v band flange right to the exh housing? ive never attempted tigging cast. i know its prob not optimal but can it be d\one? or should i tig it to a 4 bolt dp flange and bolt that down
Old Apr 26, 2005 | 06:44 AM
DaveF's Avatar
Default Re: tigging v band flange right to exh housing?? (hotrex)
turbonetics does it.....
Old Apr 26, 2005 | 08:03 AM
Justin Olson's Avatar
Default Re: tigging v band flange right to exh housing?? (Dturbocivic)
The v'band flange they put on cast is thicker then the standard flange.
Old Apr 26, 2005 | 08:13 AM
DaveF's Avatar
Default Re: tigging v band flange right to exh housing?? (Justin Olson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Olson &raquo;</TD></TR><TR><TD CLASS="quote">The v'band flange they put on cast is thicker then the standard flange.</TD></TR></TABLE>
what are you saying? they have cast v band pieces? so they are welding cast to cast?
explain further
Old Apr 26, 2005 | 09:02 AM
Keyhole's Avatar
My Innovative turbo has the vband welded to the housing as well...The flange is definetely thicker than a normal one used on an exhaust. Not sure where they get them from. The cast iron will still have to be preheated in order to weld the flange to the housing.
Old Apr 26, 2005 | 09:19 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrex &raquo;</TD></TR><TR><TD CLASS="quote">or should i tig it to a 4 bolt dp flange and bolt that down</TD></TR></TABLE>
That would be the easiest way instead of having to go through the trouble of welding to cast.
Lucky for you, PT has done all the work for you! T3 exhaust Vband flange
Old Apr 26, 2005 | 01:23 PM
hotrex's Avatar
Default Re: tigging v band flange right to exh housing?? (Finest)
i ordered a 3 inch stainless v band kit. im going to tig it to the exhaust housing...
Old Apr 27, 2005 | 05:51 PM
bigTom's Avatar
every t3 housing i make a downpipe for gets a v-vand on it... its just so much easier than a flange... i use the standard weld-on pieces and have never had a problem with one... i think iv made a total of maybe 2 downpipes using flanges... i personally hate flanges
Old Apr 27, 2005 | 06:24 PM
TeamNextGenChris's Avatar
i just finished a turbo kit for a guy who had done it.looks Mig'd to me-but definitely not from the manufacturer.
Chris
Old Apr 27, 2005 | 09:00 PM
hotrex's Avatar
Default Re: tigging v band flange right to exh housing?? (TeamNextGenChris)
thanks guys agreed flanges suck teh ********
Old Apr 27, 2005 | 11:42 PM
.RTErnie's Avatar
where can i get the weld flange for the turbine v-band...you dont use a regular pipe one!!!?!?!?! also what filler rod do you use? thanks
Old Apr 27, 2005 | 11:50 PM
project dc2's Avatar
Default Re: tigging v band flange right to exh housing?? (RTErnie)
to weld cast iron to steel you use a nickle filler. comes out really nice
Old Apr 29, 2005 | 10:32 PM
Brandon Clifton's Avatar
Default Re: tigging v band flange right to exh housing?? (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">to weld cast iron to steel you use a nickle filler. comes out really nice </TD></TR></TABLE>
More specifically, use Hastelloy W filler. There are about 50 different types of "nickel filler."
If you're welding what I presume is a .040" thick sheetmetal v-band flange (aka Marmon flange) to a ~.250" thick cast steel turbine housing, I hope your welder is good for 200 Amps. It's going to take a lot of heat to get that housing to melt.
You might want to fab up something like the PT flange posted above if your turbo will allow it.
Old Apr 29, 2005 | 10:50 PM
hotrex's Avatar
Default Re: tigging v band flange right to exh housing?? (Brandon Clifton)
i have a lincoln precision tig 185
i think it will be able to handle the task
Old May 7, 2005 | 06:46 PM
92HB_HB's Avatar
i've done it b4 w/ my lincoln 100, argon/CO gas, and L56 wire .. welded a 3" steel vband flange to my sc61 housing.. its been holding strong to this day, 16k miles..
Old May 7, 2005 | 06:59 PM
hotrex's Avatar
Default Re: tigging v band flange right to exh housing?? (92HB_HB)
i already did it, its holding up beautiful
Old May 7, 2005 | 07:03 PM
Keyhole's Avatar
So what procedure did you use to do it?
Old May 8, 2005 | 12:48 AM
hotrex's Avatar
Default Re: tigging v band flange right to exh housing?? (Keyhole)
i hit the housing with a wire wheel to clean it, then i tigged it on 150 amp draw with a 308 stainless rod.
Old May 30, 2005 | 09:55 AM
Nikoli's Avatar
can we get some finished pics? i wanna see this. i am also thinking about this going this route.
Old May 31, 2005 | 09:11 PM
hotrex's Avatar
Default Re: tigging v band flange right to exh housing?? (N I C K)
yeah i got a pic....
Old Jun 1, 2005 | 01:31 PM
Thurman Merman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrex &raquo;</TD></TR><TR><TD CLASS="quote">yeah i got a pic....</TD></TR></TABLE>
Then post it numb nuts, we wanna see lol
Old Jun 2, 2005 | 08:22 AM
PeakBoost's Avatar
B*A*N*N*E*D
Default Re: tigging v band flange right to exh housing?? (Thurman Merman)
heres a 4" vband that i welded for Acosta Motorsports 3-rotor RX-8:
we use 3SMW or NiRod44, both are high nickel content.
preheating is key.
be careful welding these with 308. i tried 308 once, about 3 years ago on my personal car, and it didnt last very long. i havent had problems with any ever since.
i do 1-2 of these daily, if anyone has any questions feel free to pm me
Old Jun 2, 2005 | 11:38 AM
B18Flip's Avatar
Default Re: tigging v band flange right to exh housing?? (PhoenixTurbo.com)
Do you guys offer this option for t3/t4 turbos?How much extra is it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhoenixTurbo.com &raquo;</TD></TR><TR><TD CLASS="quote">heres a 4" vband that i welded for Acosta Motorsports 3-rotor RX-8:
Old Jun 2, 2005 | 02:15 PM
PeakBoost's Avatar
B*A*N*N*E*D
Default Re: tigging v band flange right to exh housing?? (B18Flip)
for the t3/t4 turbos we generally recommend our vband adapter.
we offer the vband adapters in 4 and 5bolt, 2.5"($140), 3" ($150).
the adapters include a stainless vband TIG welded to the 4 or 5 bolt flange, stainless vband flange (downpipe side) and a quick release clamp. with the quick release clamp you only have to loosen the bolt and flip the latch
ken
Old Jun 2, 2005 | 04:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhoenixTurbo.com &raquo;</TD></TR><TR><TD CLASS="quote">for the t3/t4 turbos we generally recommend our vband adapter.
ken</TD></TR></TABLE>
is there any particular reason you don't recommend welding a V-band fitting directly to the T3/T4 turbos?i'd like to do this,one of the main reasons being to eliminate the possibility of leaks developing between the turbo and flange.the ability to quickly unhook the downpipe isn't a really big concern to me.
Chris
