vtec problem
Old Apr 25, 2005 | 04:16 PM
JDMBoi's Avatar
Default vtec problem
ok i have had this happen a couple times im just not sure exactly why it is happening im hoping someone can help,
when i am in vtec and i let off the gas pedal and the revs drop while still in vtec my check engine lights comes on with the vtec system failure code, why is this happening, noone else i know has this problem
Old Apr 25, 2005 | 04:24 PM
d16y8EL's Avatar
because your vtec is turning to the darkside of VTECH! muhahahha.. sorry.
probably nothing to worry about.
Old Apr 25, 2005 | 05:36 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: (d16y8EL)
bad selanoid?
Old Apr 25, 2005 | 06:25 PM
JdmB16Eg6's Avatar
65.115.123.226
Default Re: vtec problem (JDMBoi)
first thing to do if u have a vtec problem, is to check ur oil and change it. always works for me
Old Apr 25, 2005 | 06:39 PM
Audi RS4's Avatar
Lover
change your oil, check the solenoid, check wiring.
Old Apr 25, 2005 | 07:00 PM
JDMBoi's Avatar
i did change my oil, and the wiring should be fine because its stock
how do i check the selenoid?
Old Apr 26, 2005 | 06:57 AM
EJ8VTEC's Avatar
Mr. Indecisive
jus because its stock wiring doesnt mean ****, u might have a bad ground, usually if its the wiring thats the case. So check ur grounds first, thats the easiest thing to do. To see if the selanoid is bad, u need to run some power to it n see if it makes the "vtec noise". I guess u can call it a buzz or whatever
Old Apr 26, 2005 | 01:47 PM
JDMBoi's Avatar
thanks for the helps ppl
Old Apr 26, 2005 | 02:00 PM
PDM's Avatar
PDM
Default Re: (JDMBoi)
Old Apr 26, 2005 | 02:16 PM
H.A.R.T B18C1EG6's Avatar
Default Re: (PDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PDM &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
lol WTF
I had problems before and I took the VTEC solenoid out and replace the gasket and its all good in the hood now. Hope that helps
josh's ep3
Dec 8, 2008 05:59 PM
mattm868
Sep 23, 2007 02:23 PM
crx18c1
18
Apr 12, 2007 12:25 PM
Vtakkk
10
Mar 30, 2006 10:17 PM
tuckin15s_8315
Sep 28, 2005 10:12 PM
