what ecu to run with an ek h22a??
Old Apr 25, 2005 | 03:59 PM
xd69's Avatar
Default what ecu to run with an ek h22a??
as the title says i need to know which would be the best ecu. I just got jacked for my ecu and i need another one. i was running a p28 chipped before, only because that's the ecu that the guy gave me when he did the swap. the car is missing a lot sensors, i think the knock sensors are gone too. correct me if im wrong but if you use the p28, you will eliminate the use of the knock sensors right? and if you use the p13 and are missing the knock sensors then your car will run like ****?.....thanks guys!!
Old Apr 25, 2005 | 04:14 PM
SoOHiGH's Avatar
Default Re: what ecu to run with an ek h22a?? (xd69)
i would like to know as well.
Old Apr 26, 2005 | 06:50 AM
PrettyLude's Avatar
p28 has no provision for knock sensor, p13 does have a knock sensor, and yeah, your right
Scotty B
Mar 26, 2021 03:15 PM
LUDEcidDream
Engine Management and Tuning
Jul 19, 2010 02:01 PM
UncivilB18C
Apr 10, 2006 05:21 PM
xd69
Apr 27, 2005 02:34 PM
iLovPhoKing
Mar 17, 2005 08:07 AM
