NEED HELP .. something is worng with my wheel (5th gen base)
okay so I just installed kyb struts and H&R lowering springs ... 1.4 inches. I just got my axis hiros 18s with 225/35/18 wrapped around it... now here is the problem im having... for some reason my driver side back tire is rubbing the wheel well ... and when i went to the back of my car and took a look at it it looks like that wheel is tilted a bit more than the other ( more negative camber i guess).. Now i know for sure the springs and struts are done right and the wheels and tires are fine too... what could be the problem... I don't see anything bent.. but it may have gone unnoticed......... SO what i wanna know is, WHAT IS THE BEST WAY I SHOULD APPROACH THIS PROBLEM... how can i fix my camber and how much should it cost around..
thanks any help would be greatly appereciated
um, you didn't say if you have a camber kit or not? 1.4 shouldn't make too much difference, but you never know. you can get the off ebay pretty cheap- around $150 last time I was looking at them. but if it's just the one wheel, I'm not sure, I'd say look again to see if anything is bent or crooked.
No its only one wheel thats rubbing... but i think Im gonna get an allingement done and find out whats the deal
Arvid
Jul 5, 2004 02:01 PM
