Problem with rear wheel camber (5th GEN prelude base) NEED HELP !!!
Old Apr 25, 2005 | 10:08 AM
mraza's Avatar
Default Problem with rear wheel camber (5th GEN prelude base) NEED HELP !!!
okay so I just installed kyb struts and H&R lowering springs ... 1.4 inches. I just got my axis hiros 18s with 225/35/18 wrapped around it... now here is the problem im having... for some reason my driver side back tire is rubbing the wheel well ... and when i went to the back of my car and took a look at it it looks like that wheel is tilted a bit more than the other ( more negative camber i guess).. Now i know for sure the springs and struts are done right and the wheels and tires are fine too... what could be the problem... I don't see anything bent.. but it may have gone unnoticed......... SO what i wanna know is, WHAT IS THE BEST WAY I SHOULD APPROACH THIS PROBLEM... how can i fix my camber and how much should it cost around..
thanks any help would be greatly appereciated
zbra09
Suspension & Brakes
Oct 5, 2008 07:41 AM
mraza
Apr 26, 2005 04:05 PM
acuraLSSE95
Sep 25, 2004 04:35 PM
90civichb
Dec 26, 2002 09:22 AM
JoshRambo
Apr 22, 2002 04:39 PM
