dizzy wiring?!?!
hey guys,
i need to know, wire to wire the color combos to put OBD0 crx si plugs on the OBD1 civic si dizzy, if someone has a diagram of how to do it, or anythin, the best would be to just say what color wire goes to what color wire. thanks everyone.
if this does not work, could u help me out with troubleshooting? im pritty sure that i have the whole harness wired up perfect, i followed Re-Wire step by step for the resistor plug, all the red/blk wires and that yel/blk wire are in the grey 8 wire caped plug. but after finishing the dizzy ill be lost for ideas. thanks for ur help.
Not sure if this will help you since your putting obd0 plugs on your obd1 distributor,
but this pinout can be used to get an idea of which pins should go where.
All you need is a voltmeter/test light.
(droppedcrxsi) i matched all the wires color for color and the lone white wire with the yel/grn wire, and i still have no spark, i bought a new cap and rotor, ICM. i have power everywere, even at the coil tower. but nothin comin out of the dizzy, no spark at all. can u thin of anythin
Im having the same problems than u.Id rewired everything from the obd1 dizzy with the obd0 plugs and im still not having any sparks.I just finish my a6/z6 swap on my 88 crx si.Btw im using a pm6 ecu.Can someone help us out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rickcrx »</TD></TR><TR><TD CLASS="quote">Im having the same problems than u.Id rewired everything from the obd1 dizzy with the obd0 plugs and im still not having any sparks.I just finish my a6/z6 swap on my 88 crx si.Btw im using a pm6 ecu.Can someone help us out.</TD></TR></TABLE>
You can't run an obd-1 distributor on an obd-0 ECU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX »</TD></TR><TR><TD CLASS="quote">You can't run an obd-1 distributor on an obd-0 ECU.</TD></TR></TABLE>
This is correct, The OBD-1 Dizzys have like 24 teeth for the cam sensor, Were the OBD-0 Has 16. So it sends the worng signles to the Ecu.
i just finished re doing all the dizzy wiring to spec of Honda Service Manuals for a 88 crx si and a 95 civic si, the wiring is now exatcly as the manual shows it should be, we put every ground taht the manual says there should be, and nothing, the guy i bought the motor off of told me that it was runin perfectly when it came out, so im totaly lost.
PA MATT
Oct 29, 2005 10:41 PM
jdmhondageek
Aug 8, 2003 05:47 AM
