EM1 gone WILD!! HELP!!
Old Apr 25, 2005 | 07:09 AM
TheNasty0ne's Avatar
Default EM1 gone WILD!! HELP!!
First off my car wont start. The motor wont crank. Not sure why But I think its because of my alarm.
Its a remote start. Usually when I go start the car or unlock the doors with the remote the car would just unlock it or turn on the car.
But not the lights blink im not sure why
When I go start the car I hear the fuel pump like always but now the lights blink and the guage cluster blinks also im not sure why it started to do this all of a sudden. The car doesnt crank at all ignition and everything else works fine and turns on fine
I want to know why my car is doing this all of a sudden
is it trying to tell me something like a my starter when out or something?
Old Apr 25, 2005 | 07:10 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: EM1 gone WILD!! HELP!! (OoBryan)
Your alarm is going off. If you cant turn it off I would contact your installer.
What kind of alarm is it?
Jacked this off someone else's thread...
The remote looks like that except it says Two way security on the bottom and not what is in the pic. Cause I dont know what brand mine is.
Modified by OoBryan at 4:24 PM 4/25/2005
Old Apr 25, 2005 | 07:11 AM
Default Re: EM1 gone WILD!! HELP!! (White Smoke)
Everything else works fine it unlocks/locks the doors and so fourth
Old Apr 25, 2005 | 07:13 AM
athoughts's Avatar
Depending on your alarm, it may have disabled your starter
i dotn know about your alarm but if mine is going off it disables the starter, and ive also had problems with it when trying to re program it, it was like stuck on disable
Did you check your battery tho by any chance?
Default Re: EM1 gone WILD!! HELP!! (athoughts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athoughts &raquo;</TD></TR><TR><TD CLASS="quote">Depending on your alarm, it may have disabled your starter
Did you check your battery tho by any chance? </TD></TR></TABLE>
Yes I checked the battery. I even unplugged it to reset the ECU and alarm didnt work though
Old Apr 25, 2005 | 07:25 AM
Bump for some help!
Old Apr 25, 2005 | 09:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OoBryan &raquo;</TD></TR><TR><TD CLASS="quote">Bump for some help!</TD></TR></TABLE>
Old Apr 25, 2005 | 09:28 AM
Old Apr 25, 2005 | 10:21 AM
Sijray21's Avatar
try jumping the car. If that doesn't work check the wiring with the starter. Why did you get the remote starter? They're usually a pain to work with a manual transmission...and you live in phoenix.
Old Apr 25, 2005 | 02:40 PM
ironlung78's Avatar
Default Re: (Sijray21)
check the wiring by your clutch pedal..
if its an em1, its a standard so they would have had to bypass the clutch to start the car without actually being in it. if they tapped into the switch by the clutch pedal you could have possibly pulled it out while driving it.
Old Apr 26, 2005 | 07:20 AM
Default Re: (sidesi)
Alright thanks for all the input guys. I actually got the car started yesterday. I just fucked with some wires from the alarm box lol
MistahJuice
Audio / Security / Video
Jan 22, 2013 10:20 PM
TurboTeG4
Acura TSX
Jan 12, 2012 07:37 PM
kaychi
Sep 29, 2007 05:40 PM
Dan Fizzle
Jun 19, 2006 07:06 AM
1bar
May 18, 2005 04:36 PM
