Quick question about Timing Belt Kit??
Old Apr 25, 2005 | 02:07 AM
ek9800's Avatar
Default Quick question about Timing Belt Kit??
Anyone using the, Prostreetonline timing belt kit? If so, please post your evaluation on it or . Have you had any problems, and so on..
Old Apr 25, 2005 | 06:24 AM
Finest's Avatar
Default Re: Quick question about Timing Belt Kit?? (ek9800)
I bought the kit for the D16Y8. Recieved it 4 days later.
Everything you need is there. Water pump w/gasket, tensioner pulley+the little spring, timing belt.
Old Apr 26, 2005 | 08:18 PM
ek9800's Avatar
Default Re: Quick question about Timing Belt Kit?? (Finest)
ok, have you put it on? If so have you had any problems with it?
Old Apr 26, 2005 | 10:32 PM
rjay8604's Avatar
I bought one. Check the tooth profile, at first they sent me a timing belt with a trapezoid shaped tooth, but i sent it back and they replaced it with a correct rounded tooth profile belt. So so far.
Old Apr 27, 2005 | 05:34 AM
Dan GSR's Avatar
I installed one of the prostreetonline timing belt kits for a customer
horrible parts
OEM only
luishk417
Acura TSX
May 8, 2018 05:51 PM
turbohatch96y7
Mar 5, 2010 08:59 PM
92KillerBee
Apr 12, 2004 01:54 PM
