saturated injectors and peak and hold
i put a swap h22a4 97 prelude motor but it had saturated injectors but i used my old peak and hold injectors is that fine or is there anything thats going to go wrong
what size injectors did you use? Is the H obd1 or 2? Keep in mind that the obd1 (93-96) h22's used 345 cc injectors, the obd2's used 290 cc. Depending on the injectors you are running, you could be running lean.
Modified by IHateJDM at 9:59 AM 4/25/2005
