ball on shift handle slips through cup??
Old Apr 24, 2005 | 08:30 PM
thatbluecrx's Avatar
Default ball on shift handle slips through cup??
i have to hold the stick up otherwise it falls down onto my exhaust and i cant shift...
its not the bar itself falling through, just the ball on the shift handle...
do i need to replace my whole (insert term here) torque bar or is there a way to put a new bushing in there? its a hasport shift linkage with dc short throw
thanks
edit: i went to honda, who had no clue, also to try and order a bushing and they showed me a breakdown and it seams its the whole bar...
Modified by thatbluecrx at 10:33 PM 4/24/2005
Old Apr 25, 2005 | 07:08 AM
Default Re: ball on shift handle slips through cup?? (thatbluecrx)
up
Old Apr 25, 2005 | 09:04 AM
RACINTWEEK's Avatar
you can get the bushings seperate. prob like $10 total @ honda stealerships
you will need the white plastic peice and the black boot that goes in stabilizer bar
Old Apr 25, 2005 | 01:30 PM
Default Re: ball on shift handle slips through cup?? (RACINTWEEK)
yea i went to them and they didnt know what part i needed...
anyone know which one?
Old Apr 25, 2005 | 03:52 PM
hxtasy's Avatar
if it falls down the whole way through[?], than there is a problem. that ball is thicker than the flange that holds it in.
Old Apr 25, 2005 | 04:19 PM
Default Re: ball on shift handle slips through cup?? (pennhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennhatch &raquo;</TD></TR><TR><TD CLASS="quote">if it falls down the whole way through[?], than there is a problem. that ball is thicker than the flange that holds it in.</TD></TR></TABLE>
.... so what are you saying?
The ball on the shift handle 'pops' out of the stabilizer bar, what part number would i replace or do I need a whole new linkage? #15?
Old Apr 25, 2005 | 08:56 PM
once more.. up
Old Apr 25, 2005 | 10:15 PM
Dave421's Avatar
sounds like you need to check the 11/18/19/27 assembly. That's what holds the linkage up. 2 bolts at the end of the linkage above the exhaust (center console). Check it and see.
Old Apr 26, 2005 | 03:53 AM
RACINTWEEK's Avatar
Default Re:
when i had shifting problems 8 & 12 were non-existant in my stab bar and the shifter was everywhere 1st gear felt like nuetral and there was up and down movement too
like dave421 said, you should check where the stab bar mounts upp too. if #18 is shot that couls be your problem
Old Apr 26, 2005 | 05:59 AM
Default Re: Re: (RACINTWEEK)
guys, the bar DOES NOT MOVE, its fully secure. THE NUB on the shift handle is slipping through the stabalizer bar!
Old Apr 26, 2005 | 02:01 PM
Default Re: Re: (thatbluecrx)
Old Apr 27, 2005 | 08:47 AM
Old Apr 27, 2005 | 12:22 PM
Dave421's Avatar
if you're positive that the stabilizer isn't moving then it's going to be the cup. Can't tell from that pic and not sure which one actually does it but #8, 9, or 12 is going to be what holds it in the stabilizer. I've got 300k on mine and she's still tight as hell. Can't imagine what kind of hell it must have been through for it to go. It's also possible that #9 came unbolted from the stabilizer bar.
Old Apr 27, 2005 | 10:40 PM
Default Re: (Dave421)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave421 &raquo;</TD></TR><TR><TD CLASS="quote">Can't imagine what kind of hell it must have been through for it to go.</TD></TR></TABLE>
lol...
your right, you cant imagine what its been through haha
I'm still positive everything is bolted together right... any more sugguestions on wether i need a new bar or not
Old Apr 28, 2005 | 04:07 PM
Default Re: (thatbluecrx)
Alicali
Nov 30, 2016 02:57 PM
WeB
Feb 28, 2010 04:26 PM
Chillin94hatch
Jul 23, 2005 05:43 AM
Full-Race Geoff
Jan 27, 2004 08:18 PM
PhoBichNga
Jun 21, 2002 11:37 PM
