USDM H22 VS. THE JDM H22
Old Apr 24, 2005 | 04:43 PM
H22a4DarkHatch's Avatar
Default USDM H22 VS. THE JDM H22
What is the difference between the JDM H22(8200) and the USDM H22(7200RPM). Why is the redline in the JDM higher? Yes it is a stupid question ! I'm building the USDM engine, and I was just curious.
Thanks
Old Apr 24, 2005 | 04:48 PM
md23vtec's Avatar
Default Re: USDM H22 VS. THE JDM H22 (H22a4DarkHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22a4DarkHatch &raquo;</TD></TR><TR><TD CLASS="quote">What is the difference between the JDM H22(8200) and the USDM H22(7200RPM). Why is the redline in the JDM higher? Yes it is a stupid question ! I'm building the USDM engine, and I was just curious.
Thanks </TD></TR></TABLE>
And how did you come about this info because its totally wrong
Old Apr 24, 2005 | 04:57 PM
Oh . Well thanks anyways. What is the difference between the engines then? I'm pretty much new to this whole thing. Just got my car a few days ago.
Modified by H22a4DarkHatch at 6:24 PM 4/24/2005
Old Apr 24, 2005 | 05:39 PM
md23vtec's Avatar
USDM 10:1 compression
JDM 10.6:1 compression
Type-S 11:1 compression slightly more agressive cams
Old Apr 24, 2005 | 05:57 PM
Default Re: USDM H22 VS. THE JDM H22 (md23vtec)
Oh, thank you. Thats what I was looking for.
Old Apr 24, 2005 | 06:21 PM
md23vtec's Avatar
Old Apr 24, 2005 | 09:04 PM
egSpoonR's Avatar
so what is the stock redline on a JDM h22?
Old Apr 24, 2005 | 10:04 PM
DavidT or VajT's Avatar
Default Re: USDM H22 VS. THE JDM H22 (egSpoonR)
Correct me if I'm wrong, but doesn't the JDM H22's have more aggressive cams?
Old Apr 25, 2005 | 06:31 AM
Finest's Avatar
Default Re: USDM H22 VS. THE JDM H22 (DavidT or VajT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavidT or VajT &raquo;</TD></TR><TR><TD CLASS="quote">Correct me if I'm wrong, but doesn't the JDM H22's have more aggressive cams? </TD></TR></TABLE>
I haven't heard of anyone confirming (or denying) this. So I would assume that they're similar, if not the same. The Type S cams are more aggressive, of course.
The compression is the major difference since they have slightly higher octane gasoline available as compared to the **** water we pump.
Old Apr 25, 2005 | 07:47 AM
md23vtec's Avatar
And if you look I said <U>slightly</U> more aggressive on the type-s meaning more then the rest
H22Hevn
Mar 22, 2008 04:04 PM
jblack34
Feb 17, 2007 12:02 PM
HandoEX
May 3, 2006 03:12 PM
Eric91Z
May 17, 2004 09:49 PM
Neondog82
Mar 28, 2004 12:52 PM
