no heat- (Searched)
Old Apr 24, 2005 | 04:28 PM
HatchBox's Avatar
Skoobie no more...
Default no heat- (Searched)
Alright, 90 hatch w/ b16.
Ran the car for 20 minutes, only the top radiator hose was hot.
Bottom didnt get get hot at all.
Fan didnt turn on. Coolant Temp on the guage showed halfway. (normal)
And the blower only blows cold air...
Old Apr 24, 2005 | 05:19 PM
HatchBox's Avatar
Skoobie no more...
Default Re: no heat- (HatchBox)
hawt hawt hawt
Old Apr 24, 2005 | 06:17 PM
CRseXy's Avatar
thats happening to mine, minus the lower rad hose not getting hot. both hoses are getting hot. Temp guage is reading normal. and my fan isnt kicking on.
Old Apr 24, 2005 | 06:37 PM
HatchBox's Avatar
Skoobie no more...
Default Re: no heat- (pogiTSI)
Old Apr 24, 2005 | 08:17 PM
bagpipe goatee's Avatar
ok, for hatchbox, first, i'd replace the thermostat, doesn't quite make sense, but its easy and cheap.
then make sure your heater hoses are hooked up right
then make sure that the underhood valve at the firewall thats connected to the heat dial moves when you turn it
after that, check for a clogged heater core.
pogiTSI, your problem sounds electrical. was your climate control replaced recently? one of the plugs could be not pushed in all the way on it. or your squirrel cage could be dead, or the easiest a blown fuse.
Old Apr 24, 2005 | 08:28 PM
J_Pemb's Avatar
Default Re: (bagpipe goatee)
bump
my rad fan hasnt turned on by itself since the day i bought this car....
AlfieRoach
17
Jan 17, 2010 08:25 PM
accord2civic2prelude
Dec 15, 2009 03:36 PM
eg6.vtec
Jun 9, 2008 05:24 PM
technine
22
May 9, 2005 12:47 PM
ZC88CRX
Sep 2, 2003 09:57 AM
