i got oil leak, any help?
Old Apr 24, 2005 | 03:00 PM
3k9civic's Avatar
Default i got oil leak, any help?
hi guys, well i just finish putting in my b20vtec last week and it run great and since today i find out that i got an oil leak on the left side of my engine block below where vtec solinoid is at. it doesnt leak alot but still driping oil down my block. any help at all? my oil still at a cirtain level between the two dot for week now but still i can tell the oil still leaking beacause i wipe it down the oil and when i drive the car it leak again. (my set up was a b20 with a pr3 jdm head) any help?
Old Apr 24, 2005 | 03:20 PM
nocturnaldragon's Avatar
Default Re: i got oil leak, any help? (3k9civic)
clean it off, then while its running DONT drive it but sit there and look at it for a few minutes, but chances are its from your vtec solinoid, replace the gasket imo
Modified by nocternaldragon at 6:44 PM 4/24/2005
Old Apr 24, 2005 | 03:22 PM
BauleyCivic's Avatar
Risky Business
Default Re: i got oil leak, any help? (nocternaldragon)
It's either the valve cover gasket, VTEC solenoid gasket, or distributor o-ring. I replaced all 3 on my car, it ended up being the VTEC solenoid gasket (there are 2 of them).
Old Apr 24, 2005 | 03:52 PM
jameskersten1's Avatar
seems to be very commen for the oil leaks from the solenoid there. pop the VC off and replace the gasket. pretty easy to do.
Old Apr 24, 2005 | 04:14 PM
b16pwrdeg's Avatar
Check your cam seal too....mine was leaking in that area and it turned out to be the cam seal; replaced it with a STR cam seal and it hasn't leaked a drop since.
Old Apr 24, 2005 | 04:39 PM
StreetEG's Avatar
Default Re: (b16pwrdeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16pwrdeg &raquo;</TD></TR><TR><TD CLASS="quote">Check your cam seal too....mine was leaking in that area and it turned out to be the cam seal; replaced it with a STR cam seal and it hasn't leaked a drop since.</TD></TR></TABLE>
I had a leak next to my distributor just 2 months ago and a fresh aebs cam seal took care of it right away...
BamaSkater09
Dec 8, 2013 04:24 PM
airikkCRX
Dec 16, 2010 02:49 AM
jdm ek9 101
May 10, 2007 11:30 AM
redracer1024
Feb 17, 2006 11:04 PM
trooper0641
Sep 9, 2004 04:57 PM
