Opening up brake prop valve
Has anyone ever successfully taken apart a prop valve and used if afterwards? I took my 4040 apart (during my rear disc conversion) just to swap brackets... the helms manual says to never take them apart... could I have screwed it up?
Has anyone ever successfully or sunsuccessfully opened up a prop valve?
I had to take mine apart to swap over my civic bracket. And then I put it back together the same way I took it apart. Still works fine. Just be carefull, because it is under pressure from the spring inside. Take ur time, and you'll do fine
90HFCrX
13
Apr 8, 2012 10:57 AM
crexer
10
Apr 17, 2004 09:13 PM
