Opening up brake prop valve
1 Post
Has anyone ever successfully taken apart a prop valve and used if afterwards? I took my 4040 apart (during my rear disc conversion) just to swap brackets... the helms manual says to never take them apart... could I have screwed it up?
Has anyone ever successfully or sunsuccessfully opened up a prop valve?
I had to take mine apart to swap over my civic bracket. And then I put it back together the same way I took it apart. Still works fine. Just be carefull, because it is under pressure from the spring inside. Take ur time, and you'll do fine
90HFCrX
13
04-08-2012 10:57 AM
crexer
10
04-17-2004 09:13 PM
