MPFI conversion HELP ASAP
Old Apr 24, 2005 | 01:58 PM
menappi's Avatar
Default MPFI conversion HELP ASAP
yes i did a search, but i need to know what i need to do to convert a dx (dpfi) to mpfi using the si engine harness. im doing it for a friend and he kept the si harness on the motor and is trying to do it like that. he butchered all the under dash ecu plugs so using the dx harness prob wont be an option.
Old Apr 24, 2005 | 02:00 PM
tur3oDC4's Avatar
Default Re: MPFI conversion HELP ASAP (menappi)
Bump for Lakewood
Old Apr 24, 2005 | 04:09 PM
FalkenSiR's Avatar
Default Re: MPFI conversion HELP ASAP (whitepoweredlsvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menappi &raquo;</TD></TR><TR><TD CLASS="quote"> he butchered all the under dash ecu plugs so using the dx harness prob wont be an option. </TD></TR></TABLE>
and why would he do this? There must be a really good reason for this. One, he really knew what he was doing and he needs no help: NO. Two, he needs help but forgot to ask around; maybe. He did something really stupid and he is stuck with a hacked up wiring job to do that won't even give him 20 hp; yes.
cliffs; he needs to ask around before messing around with his car.
Old Apr 24, 2005 | 04:14 PM
lodo1's Avatar
he better get really acquainted with a multimeter. start finding where each and every wire goes.
Old Apr 24, 2005 | 09:40 PM
menappi's Avatar
it cant be that hard..i figure i just need to run wires from the harness to the ecu..theres not that many things on the motor.
Old Apr 24, 2005 | 10:41 PM
Rywire's Avatar
Default Re: (menappi)
Get the ecu diagram, and get soldering. Dont use a si eng harness in a dx car, it wont work.
Ryan
Old Apr 25, 2005 | 06:00 AM
crx-neo's Avatar
Default Re: Dual-Point to Multi-Point conversion
I've been doing loads of searching for wiring and pin-outs for my 89 CRX stock harness... Last night I found in one of my old "Honda Tuning" magazines DPFI to MPFI wiring conversion. Just what you're lookin for! The issue's Headline was "To The Nines" and it was kind of a purple cover. I don't remember the issue number or date but I'm sure the HT website has the article in their archives. Also in that issue non-vtec to v-tec conversion.
Old Apr 26, 2005 | 01:26 PM
som1_2race's Avatar
Default Re: Dual-Point to Multi-Point conversion (crx-neo)
Would that article work for the 89 & 90 Civic HB DPFI to MPFI?
Could you scan it for us to see?
lrcrx90
May 29, 2006 08:14 PM
2kTeg
Jan 29, 2006 08:36 AM
415Hatch
Jun 7, 2005 04:04 PM
bipedbear
Apr 21, 2005 11:32 PM
badoubled
Nov 10, 2003 08:42 AM
