.Radiator Fan doesn't turn on???
had the same problem....it was my thermoswitch (fan switch) its the sensor in the thermostat housing....cost like $50 for a new one from honda up here in canada.
To confirm that this is your problem try jumping the thermoswitch, do this by putting a piece of wire or a paper clip in the plug jumping it or completing the circuit. If the fan turns on when you start the car with the thermoswitch jumped then its safe to say that this is the problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zman »</TD></TR><TR><TD CLASS="quote">had the same problem....it was my thermoswitch (fan switch) its the sensor in the thermostat housing....cost like $50 for a new one from honda up here in canada.
To confirm that this is your problem try jumping the thermoswitch, do this by putting a piece of wire or a paper clip in the plug jumping it or completing the circuit. If the fan turns on when you start the car with the thermoswitch jumped then its safe to say that this is the problem.</TD></TR></TABLE>
Whatever
Apr 23, 2009 09:49 AM
